Initial timing for new camshaft
Oct 11, 2017 | 01:36 PM
What would be a good starting initial timing to start with
this cam?
Lift .504/.525
Duration @ .050 : 233/241
Adv Duration: 276/284
It is lunati's voodoo series cam. Is 16 degrees a good starting point?
Oct 11, 2017 | 01:42 PM
I'd say anywhere from 10 to 20 until you get the cam broken in and ready for the fine tuning.
Oct 11, 2017 | 01:44 PM
Quote:
Originally Posted by
Oldguard 7
this cam?
Lift .504/.525
16-18 would be good. That will keep your exhaust gas temperature modest, and it will allow the engine to start and run immediately with no issues.
Lars
Oct 11, 2017 | 08:05 PM
Oldguard 7
this cam?
Lift .504/.525
With an HEI 12 to 14 degrees of initial advance works well because the mechanical advance produces 20 degrees.
Oct 11, 2017 | 09:39 PM
I agree with the above. Run 16-18 initial and 36 degrees all in. If you have an HEI where you can't limit the mechanical advance, you'll have to run less initial (around 12 degrees) and then possibly make up for it with vacuum advance.
