Water pump.
Old Nov 29, 2017 | 06:08 PM
jhopper408's Avatar
jhopper408
Default Water pump.
Is it worth putting a high flow water pump on my 383S. I have one in a box brand new. Will it make a big difference?
Old Nov 29, 2017 | 06:14 PM
Big2Bird's Avatar
Big2Bird
If the car is running hot it will help.
If the car is not, save it for when the old one dies.
My 2 cents.
Old Nov 29, 2017 | 06:29 PM
jhopper408's Avatar
jhopper408
Okay thanks. That makes sense.
Old Nov 29, 2017 | 10:42 PM
NewbVetteGuy's Avatar
NewbVetteGuy
I'd add one more scenario: If you plan to run an underdrive crank pulley, a high flow water pump can help maintain the same cooling ability as a "normal" water pump when the water pump is underdriven and with less parasitic drag.
Adam
Old Nov 29, 2017 | 11:10 PM
jhopper408's Avatar
jhopper408
Hey Anam. I don't really understand the mechanics of what your saying. So are you suggesting that I put it on?
John
Old Nov 29, 2017 | 11:21 PM
NewbVetteGuy
John
http://www.hotrod.com/articles/hrdp-...ps-suck-power/
I didn't understand that you already had the high flow water pump.
If you don't have a heat problem, a high flow pump won't fix anything but it WILL steal more HP. If you swap to an underdriven crank pulley you get good cooling and less parasitic power loss (slightly more parasitic loss than an electric pump but without the reliability issues with an electric pump).
Bottom-line: IMO, high flow pump without an underdrive crank pulley not usually a good idea, with one, a great idea.
Adam
Old Nov 29, 2017 | 11:37 PM
jhopper408's Avatar
jhopper408
Thanks Adam. Thats exactly what I wanted to hear. Now it makes sense. Thank you! Sure don't want to lose HP.
Old Nov 30, 2017 | 12:29 PM
BKbroiler's Avatar
BKbroiler
Just to add another perspective - I have a LOW flow, Moroso, aluminum water pump on my 383 with no cooling problems.
Old Nov 30, 2017 | 12:52 PM
jhopper408's Avatar
jhopper408
That sounds even better. Thanks!
Old Nov 30, 2017 | 02:35 PM
7T1vette's Avatar
7T1vette
For MOST applications, a standard flow pump will be fine for your Chevy V8 engine.
Old Nov 30, 2017 | 03:59 PM
jhopper408's Avatar
jhopper408
Thanks. Stock one will stay on!
To Water pump.
