Head Lamp, REALLY? How difficult can this be?
Good luck!
Stump
Anyway, I did manage to remove the chrome trim ring around the loosened but in-the-way bezel, tested the head lamp bulb ok, so I reinstalled it and it now works, so it appears to have been a connection issue. This was very much like building a ship in a bottle.
I did also discover, in removing the chrome trim ring that PO had evidently stripped out the threads on the mounting cup (or whatever it is) that the lamp mounts into. He had a retaining nut on back of the top screw which holds the chrome ring.
This is humanly impossible to replace working around the freakin' bezel, so I only have two of the three retaining screws in place. I guess my next project will be to figure out how to temporarily adjust the headlight doors so I can at least remove the bezel long enough to replace the headlight mounting assembly with the stripped out hole.
At least my head lights are working, for the time being.....
In looking at the headlight doors again for photos closed I suppose I could raise the passenger side 1/16 of an inch all around, I will have to see if that solves the problem. Thanx for the input....
Sometimes the rubber pad is missing. If that stop isn't touching, then there may be something wrong with the overall mechanism adjustment and much more complicated to get into.
M
The headlight door does look a 'little' low, but doesn't really seem low enough to give you trouble getting the bezel off the headlight housing.
Do you sense that the bezel isn't completely free of the housing, or is it trapped by the opening in the hood surround?
Have you tried to take the other bezel off to see if that tells you anything?
Regards,
Alan
QUOTE]
have you tried a bigger screw to see if that holds ? the cup is only sheet metal , nothing worse than a shaky light beam at night from a loose bulb !
Regards,
Alan
Once I can get the bezel out I'm sure I can get a fix on that stripped out trim screw hole. The way I was working on it today with the bezel in the way you would need to have hands the size of a Ken doll to reach around back of that trim ring to hold the backing nut in place.
If that screw is out all the way and you need more room to lift up
Go under the car and remove the 4 springs the cotter pin and pull #8 out.
You will then be able to lift the headlight assembly.
I believe the stripped headlight and bezel mount tabs is a pretty common issue. Clip nuts might be a easier/cheaper fix than replacing parts.
