Replacement carb for 1979 L48
Old Jan 11, 2018 | 05:18 PM
Philgran's Avatar
Philgran
Default Replacement carb for 1979 L48
I want to replace the carb on my 1979 C3. The mechanic I work with has strongly recommended that route as opposed to a rebuild kit. I would like to try and improve my performance on the 350 smallblock. I took the air cleaner off to see what the current carb is. It looks like the word "Rochester" is on the side. Some other letters look like "QUAR". Could someone please recommend a good replacement carb? The car was originally sold into California and I wonder if Chevy did something to the carb setup or use a different model carb then was on other C3s of that time period. I want to replace the carb so the car runs better. Thank you very much!
Philgran
Philgran '79 C3 Carb
Last edited by Philgran; Jan 11, 2018 at 05:23 PM. Reason: Want to add picture of current carb
Old Jan 11, 2018 | 05:29 PM
Dynra Rockets's Avatar
Dynra Rockets
I'm not aware of any "new" Rochester Quadrajets. Rebuilt is your only option if you want to keep the carb factory. There are numerous places where you can buy an already rebuilt carb on exchange.
There are a couple of forum members that will rebuild for you also.
For "new" the Holley spreadbore series (4165/4175) are bolt on but they do need to be tuned to what your car wants.
Old Jan 11, 2018 | 05:36 PM
jb78L-82's Avatar
jb78L-82
I have had a Holley 4175 650 CFM vacuum secondary Qjet replacement carb on my L-82 since 1985 and now still on the rebuilt 355 L-82 355 (carb rejetted) with 450+ Gross HP....great replacement carb for the Qjet.
Lars is also a great option for your OEM Qjet for him to rebuild it.
Old Jan 11, 2018 | 05:45 PM
Philgran's Avatar
Philgran
Default Holley Spreadbore Series
Thank you, what would be the positives of the Holley?
Old Jan 11, 2018 | 05:52 PM
'75's Avatar
'75
Contact Lars v8fastcars@msn.com , he will make your carb work better than new and nothing on your engine will need to be modified like it would if you went to an aftermarket carb.
Old Jan 11, 2018 | 07:14 PM
VintageMusclecar's Avatar
VintageMusclecar
Rebuild your original Quadrajet.
Old Jan 12, 2018 | 02:15 AM
7T1vette's Avatar
7T1vette
If that is the original Q-Jet which came from the factory on that engine (check the build date), you should just rebuild the carb with a kit you can purchase at NAPA or other decent car parts store. If that is a replacement carb which was purchased as REBUILT, you should send it to Lars Grimsrud (e-mail request to him at V8FastCars@msn.com) for having it properly rebuilt.
Swapping over what you now have (a stock induction system) to a square-bore carb would require a new intake manifold, etc. The carb you have is BETTER than any similar sized carb you can purchase; and the new carb purchase price is at least TWICE what it would cost to have Lars rebuild the one you have.
Old Jan 12, 2018 | 06:50 AM
jb78L-82's Avatar
jb78L-82
The Holley 4175 650 CFM vacuum secondary carb is a direct replacement for the Qjet (it even has small primaries and giant secondaries like a Qjet) and is a spreadbore carb and will fit with almost no modifications on the GM intake...as an FYI
Old Jan 12, 2018 | 09:00 AM
stingr69's Avatar
stingr69
That Holley is easier to modify as compared to the Quadrajet but if you like to just drive a well running car the Quadrajet works best. I do run Holleys on other cars but the Quadrajet is the best carb for "set it up and forget about it" closed hood drivers. They work great when clean and adjusted right. California emissions calibration may be a bit too lean but nothing that could not be fixed when it is apart.
Send it to Lars is my advice. I carried mine to him years ago and it still works great.
Old Jan 12, 2018 | 01:12 PM
7T1vette's Avatar
7T1vette
A "new" Holley will still cost twice as much as rebuilding the Q-Jet properly. The Holley will give no better performance and [most likely] less economy.
But the ability to swap over to that Holley [which is a good carb] is correct. If you go with the Holley, you will still have to figure out reconnecting all the emissions hoses, etc.
Your choice...
Old Jan 12, 2018 | 02:01 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Why a NAPA kit for the OEM carb but send the replacement carb to Lars?
What's the difference?
Old Jan 12, 2018 | 02:28 PM
Dynra Rockets
There is rebuilt and then there is REBUILT. A major difference.
One company may consider "rebuilt" as cleaning it and throwing a new gasket/seal kit in it.
A good rebuild service will also measure for warp/leakages, validate it functions as should/make adjustments as needed, tune to your specific engine specs, etc. Probably 3-4 hours of billable work.
If someone offers a "rebuilt" carb for $100 + exchange then that means they spent about 20-30 minutes on it.
Sending a carb to LARS or anyone that is intimately knowledgeable of the operation and gotchas is money well spent. (disclosure: I do not know LARS as I do my own work but lots of positive threads here about his work)
Old Jan 12, 2018 | 02:44 PM
Peterbuilt's Avatar
Peterbuilt
If your handy a rebuilt kit lets you change the needle and seat and the accelerator pump and the gaskets.
A commercial rebuilder may swap parts, jets sizes or rod sizes and the carb may never run correctly.
Lars was employed at GM in the q-Jet dept.
He will fix your carb correctly.
With a new carb, the fuel, accelerator cable and other lines may need to be modified.
Old Jan 12, 2018 | 03:59 PM
REELAV8R's Avatar
REELAV8R
Or if your a DIY guy get Cliff Ruggles' book buy the rebuild kit from him and do it yourself.
My Q-jet was a POS originally. After following Cliff's book and some of his performance tuning tips it now runs like fuel injection on a 440 HP 350.
Old Jan 12, 2018 | 04:47 PM
Big2Bird's Avatar
Big2Bird
Originally Posted by cardo0
Well is there any problem with the carb now? I can see from the picture it's a electronic controlled q-jet.
Nope. Not an E4ME
Old Jan 12, 2018 | 07:20 PM
Big2Bird's Avatar
Big2Bird
Old Jan 12, 2018 | 07:46 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
pretty crusty looking carb.
quite a bit of linkages and pull offs.
maybe warped.
I don't know your time requirement.
Can you remove and install a carb at home?
do you need the car running right away?
depending on the answers,
buy a Q-jet with they same numbers from a parts house.
all lines, fittings, hookups will be the same and an easy swap.
holley or some other carb will require time to adapt to the
lines and fittings. choke.
send yours to lars.and wait
buy a replacement and send your orig to lars.
Q-Jet is a good carb when rebuilt right.
To Replacement carb for 1979 L48
Old Jan 12, 2018 | 08:42 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Originally Posted by Big2Bird
Nope. Not an E4ME
Oh your right. I was looking at the wrong side of the carb and thought I saw an electrical connector.
I should say no more.
Old Jan 12, 2018 | 09:22 PM
jim in oregon's Avatar
jim in oregon
Philgran
Phil..IF YOUR VETTE WAS BUILT FOR SALEIN CALIFORNIA..there's some emission restriction on that carb..THE NUMBER on the side of the carb will tell the tale..I rebuilt the Rochester QJet on my '78L48 350..but mine was an Oregon car..UPgraded the float to a better one..filter etc..all stuff from a local auto parts place that knows their stuff...Car runs great..starts great..accelerates fine..Do it right but don't replace with the California stuff.Lars or another qualified mechanic can rebuild your Rochester and do it welll.Jim
Old Jan 12, 2018 | 09:30 PM
Big2Bird's Avatar
Big2Bird
Us 81 guys see them in our sleep.
Evil creatures. Lars won't poke them with a stick.
I have all The GM gizmos to do them correctly. (If that is a thing).
