Dyno Explosion: 3000hp Cummins Diesel
Old Jan 12, 2018 | 02:36 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Default Dyno Explosion: 3000hp Cummins Diesel
Ummm.... Didn't think an engine explosion this big was possible.
Adam
Old Jan 12, 2018 | 02:41 PM
JoeMinnesota's Avatar
JoeMinnesota
Quite...ummm...catastrophic. The shop I ran mine at last summer had a patch on the steel shop door. The owner said an iron flywheel failed and literally punched 1/2 of the flywheel into the door.
Old Jan 12, 2018 | 02:45 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
damn
Old Jan 12, 2018 | 04:44 PM
76strokervette's Avatar
76strokervette
When you run over 120 lbs of boost the explosions can be quite dramatic.
Old Jan 12, 2018 | 05:48 PM
derekderek's Avatar
derekderek
What I like is the late shots showing the crank and rods still spinning in the mains after the whole top blew off. Is that a 6BT?
Old Jan 12, 2018 | 06:57 PM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Holy smoke batman
Old Jan 12, 2018 | 06:59 PM
DUB's Avatar
DUB
DUB
Old Jan 12, 2018 | 07:25 PM
v2racing's Avatar
v2racing
I do believe they exceeded the load capacity of the engine block.
Mike
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
146 lbs of boost ! Try that with your big block. Wow .
Old Jan 12, 2018 | 07:37 PM
Revi's Avatar
Revi
I think if they just back the timing down a couple of degrees they should be good.
Old Jan 12, 2018 | 07:38 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
I think I need to go change my shorts ��
Old Jan 12, 2018 | 08:28 PM
PainfullySlow's Avatar
PainfullySlow
Wow, that is impressive and brings new definition to 'catastrophic failure'
Old Jan 12, 2018 | 09:02 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Sounded like a nice hi po gas engine until it blew. I own and drive a Cummings and never heard a diesel sound like that.
Old Jan 12, 2018 | 09:40 PM
Jackie Chan's Avatar
Jackie Chan
I'm pretty sure in jb weld will fix that
Old Jan 12, 2018 | 10:31 PM
7T1vette's Avatar
7T1vette
Obviously didn't have any auto shut-down systems on that rig...or they didn't work well.
Glad I wasn't anywhere near that test.
Old Jan 12, 2018 | 10:38 PM
Big2Bird's Avatar
Big2Bird
Mike
Old Jan 13, 2018 | 05:49 AM
Blue79's Avatar
Blue79
Thought there would be a lot more oil thrown around. Didn't appear to be much/any?
To Dyno Explosion: 3000hp Cummins Diesel
Old Jan 13, 2018 | 07:42 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Jan 13, 2018 | 09:15 AM
pws69's Avatar
pws69
Oil??? I thought YOU put it in........
Old Jan 13, 2018 | 10:22 AM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
So, that's bad....right?
3 different cameras set up to capture a dyno run? Is that kinda standard practice, or is this staged?
