4 bolt main conversion.
Old Feb 26, 2018 | 01:02 AM
Black04Vert's Avatar
Black04Vert
Originally Posted by Muzzyzx7rr
Well my 2 bolt is now a 4 bolt main. Next stop line hone. That was a fun project and fairly easy but my caps were almost a perfect fit so that helped tremendously.
The upper untapped hole doesn't appear to be on the same axis as the original threaded hole. It looks shifted right vs the original hole. Is this just an optical illusion or is there a purpose for that?
Old Feb 26, 2018 | 07:36 AM
Muzzyzx7rr's Avatar
Muzzyzx7rr
very well could be off center, I didn’t locate center of block casting, I bolted the cap on with the center bolts and aligned to the bottom then tightened and then found center of outside hole of cap and drilled in that spot. Seems gm’s tolerance were pretty dang loose when it came to hole placement.
Old Feb 26, 2018 | 08:15 AM
Vortecpro's Avatar
Vortecpro
When the center 3 caps are replaced with billet caps the boring bar is registered off the original front and rear cap, not sure how you would bore that will all the caps replaced. After thinking about it, you could replace the center 3 then located off them after they were cut, then cut the front cap, then located off number 1 and 4 and cut the rear cap and then of course line honed it
Old Feb 26, 2018 | 08:38 AM
Muzzyzx7rr's Avatar
Muzzyzx7rr
yes that makes sense.
Old Feb 26, 2018 | 11:23 AM
BROKEN RODS's Avatar
BROKEN RODS
I have the same set up and thats what I would do. I actually have some junk caps that have been cut down and narrowed for line boring I use them on 1 & 4 when cutting the 3 center caps in and front and rear 2 & 4 journals seems to work fine. Always finish with an align hone. The PLB-100
Old Feb 26, 2018 | 01:27 PM
PainfullySlow's Avatar
PainfullySlow
Looks good! Very cool to do this yourself.
I wish I had a bridgeport :/ I would do all sorts of crazy things with it.
Old Feb 26, 2018 | 04:31 PM
Muzzyzx7rr's Avatar
Muzzyzx7rr
big 3 ton okuma lathe behind it😊... between those two I can cause a lot of trouble haha.
Old Feb 27, 2018 | 08:17 AM
Muzzyzx7rr's Avatar
Muzzyzx7rr
thats a good point, I wonder if it would help for me to take cap #1 and #5 to the machine shop so they can bolt on and indicate of those and bore the center 3 and then take them off and indicate of #2 #3 and #4 to do #1 and 5?
Old Feb 27, 2018 | 12:27 PM
derekderek's Avatar
derekderek
Might make sense...
Old Feb 27, 2018 | 01:57 PM
Muzzyzx7rr's Avatar
Muzzyzx7rr
I just called the machine shop and he said it was fine just bring all my original caps in with the block👍
Old Mar 2, 2018 | 09:31 PM
Milan454's Avatar
Milan454
I have a few 4 bolt cap sets. The last conversion was cake. The one before that had my machinist cussing me out. Its amazing how much they vary...
Old Mar 2, 2018 | 09:42 PM
Muzzyzx7rr's Avatar
Muzzyzx7rr
i got it to the machine shop and he said it looked very good but yes i think it’s all in the caps. If you have the right equipment and basic knowledge then it’s easy but if the caps aren’t dang close to your last ones you just opened a can o worms
Old Mar 3, 2018 | 08:12 AM
  #33
Milan454's Avatar
Milan454
I try and collect the caps so I can swap a few around for a close fit.
Old Mar 3, 2018 | 01:42 PM
  #34
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
Nice job! What is the price of machining the block in US?
Old Mar 3, 2018 | 03:57 PM
  #35
Muzzyzx7rr's Avatar
Muzzyzx7rr
i think my quote was somewhere around 600
Old Mar 3, 2018 | 08:29 PM
  #36
calwldlife's Avatar
calwldlife
St. Jude Donor '22
well done
good to see what you did.
can't be too detailed when it comes to
machining
Old Mar 3, 2018 | 09:26 PM
  #37
Grumpy 427's Avatar
Grumpy 427
I picked up a nice std bore 4 bolt main block for $250.00 Planning a 7200 rpm 331Ci build for a 64 Chevy II i am looking at. Local guy here has close to 25 four bolt main block that he has collected
To 4 bolt main conversion.
Old Mar 3, 2018 | 09:54 PM
  #38
Muzzyzx7rr's Avatar
Muzzyzx7rr
funny how some people come about ending up with such cool things
Old Mar 3, 2018 | 09:55 PM
  #39
Muzzyzx7rr's Avatar
Muzzyzx7rr
Originally Posted by calwldlife
well done
machining
thank you very much and no you cant
Old Mar 3, 2018 | 10:00 PM
  #40
Grumpy 427's Avatar
Grumpy 427
I have a great engine builder with a killer machine shop. The sad thing is, he has no apprentice to learn and take over the shop when he decides to hang it up.
