Tach Cable Housing too Long?
Old Mar 14, 2018 | 10:14 AM
Pikeslayer's Avatar
Pikeslayer
FYI. The ferrule goes on the tachometer end.
Old Mar 14, 2018 | 10:34 AM
Alan 71's Avatar
Alan 71
Hi P,
"According to Paragon they are made in India."
Well... that gives me a lot of confidence!!
Regards,
Alan
Old Mar 14, 2018 | 10:39 AM
Peterbuilt's Avatar
Peterbuilt
Hi Pikeslayer,
Did you say you tried reclocking the distributor?
Old Mar 14, 2018 | 11:02 AM
Pikeslayer's Avatar
Pikeslayer
I did, but not to the extreme that your document shows. I may just do that though.
Old Mar 14, 2018 | 11:41 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
That's what I did , gave the cable a much cleaner straight route , it does seem odd , but it works ,
But I never moved the wires on the cap .
Old Mar 14, 2018 | 05:30 PM
Surfer69's Avatar
Surfer69
ZIP sent to me backwards then. Probably explains why it doesnt work and now I have to get under the dash again.
Old Mar 15, 2018 | 07:37 AM
Pikeslayer's Avatar
Pikeslayer
So I pulled off the crimped on housing end at the distributor and removed about 5/8" of casing. Reinstalled the housing and wala! Tach works. Probably have to do the same with my speedo cable now.
Old Mar 15, 2018 | 12:21 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
Perfect love a good ending
Old Mar 15, 2018 | 12:40 PM
jhudec's Avatar
jhudec
The replacement housings are longer than original housings. I searched a while for an original in good condition.
