70 ac condensor question
Old Mar 30, 2018 | 05:41 PM
Ray Schmidt's Avatar
Ray Schmidt
Default 70 ac condensor question
I have a question about attaching the ac condensor to the radiaror core support. Are there any kind of bushings used or do you attach it dircet to the core support? Also what kind of fastener do you use on the bottom of condensor to attach it to the core support. Thanks, Ray.
Old Mar 30, 2018 | 07:13 PM
DUB's Avatar
DUB
If I am not mistaken there are special bushings with steel sleeves in them. The AIM will show this and how it attaches.
DUB
Old Mar 30, 2018 | 11:38 PM
Ray Schmidt
Default 70 condensor
Originally Posted by DUB
If I am not mistake there are special bushings with steel sleeves in them. The AIM will show this and how it attaches.
DUB
Thanks for the help. I will recheck the AMI.
Old Apr 1, 2018 | 09:35 PM
Ray Schmidt
bump
Old Apr 2, 2018 | 06:02 PM
DUB's Avatar
DUB
https://www.zip-corvette.com/73-82-a...shing-kit.html
Old Apr 2, 2018 | 06:22 PM
Ray Schmidt
DUB, Thanks for the information but that is for a 1973-1982. Thanks, Ray.
Old Apr 2, 2018 | 07:12 PM
DUB's Avatar
DUB
I believe it is the same but I will double check it.
DUB
Old Apr 3, 2018 | 07:20 AM
Alan 71's Avatar
Alan 71
Hi Ray,
The NCRS 70-72 TIM&JG, in the A/C area of the Chassis Section, indicates that the condenser is mounted directly to the core support at it's four corners using flanged, indented hex head, screws.
There is no mention of, nor does photo appear to show, any type bushing being used at that connection.
Regards,
Alan
Old Apr 3, 2018 | 07:44 AM
Ray Schmidt
DUB
Thankt you!
Old Apr 3, 2018 | 07:49 AM
Ray Schmidt
Originally Posted by Alan 71
Hi Ray,
Regards,
Alan
Allen, Thank you very much for clearing that up. Your commitment to this fourm and knowledge are second to none! Thanks once again, Ray.
To 70 ac condensor question
