Very Strange electrical problem
Old Mar 31, 2018 | 04:23 PM
Dawgbroke's Avatar
Dawgbroke
Default Very Strange electrical problem
Never seen this one. 1976 Corvette. All my parking lights, running lights, headlights, brakelights work...
Right turn signal does not blink.
and here's the strange part:
brake lights work fine, unless the headlights are on. The right brake/running lights go completely off when the brake is pressed, but again, only the right side, only when headlights on. Both brake lights work when the headlights are off, but my wife did notice that the right is not as bright as the left.
Ideas?
Old Mar 31, 2018 | 04:31 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
did you change the bulb?
Old Mar 31, 2018 | 07:47 PM
Big2Bird's Avatar
Big2Bird
9 time out of 10, a goofy operation is a lost/bad ground, and the power is taking an alternative path.
Old Mar 31, 2018 | 11:09 PM
Richard454's Avatar
Richard454
Check the bulb/socket on the right side brake-
Sounds like you have either an 1156 single filament bulb there or the 1157 double filament in the wrong way.
Old Apr 1, 2018 | 08:27 AM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Old Apr 1, 2018 | 07:27 PM
Dawgbroke's Avatar
Dawgbroke
I changed the bulb, It is the correct 1157... but I'll check if it's the wrong way.
Wasn't aware there was a right/wrong way.
Thanks for the replies.
PJ
Old Apr 1, 2018 | 08:10 PM
'75's Avatar
'75
It may be a ground problem. those sockets have a ground connection that corrodes and rusts causing problems. To check the ground, just remove the socket with the bulb still installed and touch the brass edge of the bulb with a grounded wire to see if the bulb brightness changes.
Old Apr 1, 2018 | 08:17 PM
Peterbuilt's Avatar
Peterbuilt
As '75 said. here's a picture:
Old Apr 1, 2018 | 08:34 PM
Dawgbroke's Avatar
Dawgbroke
This sounds like the point to start from, which was just what I was looking for. I'm out of town for a few days, so I won't be able to check, but REALLY appreciate the pointers.
I feel it is a ground issue as well, just needed a place to start looking.
PJ
Old Apr 2, 2018 | 10:06 AM
lionelhutz's Avatar
lionelhutz
It's the ground to the socket.
The light is grounding itself through the other bulb filament and then to the other bulbs that are connected to that wire. During the day, the brake and signal is duller because you're actually seeing the tail light filament instead of the proper turn/brake light filament.
During night, the light goes off because when power is applied to both the tail and turn/brake filaments there is no no path for power to flow through a filament and make it light. Every part of the bulb has 12V applied so it can't light.
If you find it's the socket and replace it, test it temporarily before making the wire connections permanent. It's become too common for parts store sockets to have wire colors that match the GM wires, but do a different function. In other words, if you match wire colors the tail light filament might be used for brake/turn and the brake/turn filament used for the tail light. It would at first seem to work OK except you can't see the brake/turn light with the headlights on.
Old Apr 14, 2018 | 10:52 PM
Dawgbroke's Avatar
Dawgbroke
Just want to thank all for this. It was the socket. Light was in correctly, but the ground was bad. Replaced the socket and all is good.
Thanks again.
PJ
Old Apr 14, 2018 | 11:08 PM
'75's Avatar
'75
Glad you got it fixed!
Old Apr 15, 2018 | 04:10 AM
7T1vette's Avatar
7T1vette
Hey! We need to "party down".
Someone listened to advice given...actually tried to determine fault cause based on that advice....and fixed the problem!
Old Apr 15, 2018 | 09:57 AM
Dawgbroke's Avatar
Dawgbroke
That's why I asked the question lol
To get advice.
Old Jul 4, 2018 | 09:29 PM
Dann Kirschman's Avatar
Dann Kirschman
Cruising
Default No brake lights or hazard fashers.
I don't see a resolution to this problem
I know before the for t and rear bumpers were replaced all lights worked
It is a 1976 corvette .
I have checked wires at rear under car . All appear to be hooked up
what I have tested . checked watt the fuses with a test light .
Disconnected the brame light switch jumped the orange wires to the white. No lights I pulled the light bulbs new 1157. And tested the sockets with a test light have power tested with a DMV . 12 volts put 1 bulb in no power no voltage at either light socket
the turn/ marker back up lights all work front and side maker/turn work .
I replaced the turn signal switch .
Still no brake or hazards .
I found a large ground wire at front drivers side not hooked up I ran out.of time to hook it up I cleaned the wire and a spot touched it to the bare metal ..no flashers and tried brake lights with a pry bar to hold pedal down no brake lights
this is driving me insane . Any help would be appreciated . in advance .
Old Jul 4, 2018 | 09:40 PM
derekderek's Avatar
derekderek
You have power at your tail lights. You have no ground path. Run a wire from the frame to each socket. The outside of the socket, not either terminal.
Old Jul 4, 2018 | 10:09 PM
Dann Kirschman
Cruising
They ground on the inside of the socket I will give it a shot on sat when I have some time .
tail lights work brake lights don't . I will try the ground from the rear frame this weekend I hope it's that easy lol should b
To Very Strange electrical problem
Old Nov 22, 2021 | 07:23 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Originally Posted by EdgySloth
Hi all, this may be a long shot, but could someone please show me with an image where's the fuse to turn off the day time running lights? My expertise level with Corvette is still quite limited and one of the pending requirements to pass local inspection here is to ensure these are not on. Thanks!
You're responding to a 3 year old post in the C3 section (no DRL's here).
You should start a new thread in the C5 section.
Old Nov 22, 2021 | 07:39 AM
EdgySloth's Avatar
EdgySloth
My apologies! Will ensure this is in the right section. Thanks for the headsup
Old Nov 26, 2021 | 09:59 AM
TL79C3's Avatar
TL79C3
Banned Scam/Spammer
It don't matter if someone responds to an old thread. There are no time limits on them. If there was they would be taken down. So more input the better. And people read them to learn about their car. And how to fix them based on others experiences. I KNOW I HAVE!!!
