Lower Radiator Hose no spring?
Old Mar 31, 2018 | 07:38 PM
Tim81's Avatar
Tim81
Default Lower Radiator Hose no spring?
I need to replace the lower radiator hose on my 81. I searched for a new hose with the anti-collapse spring but could not find one at any of the local parts stores. The counter person told me that the new hose is reinforce so the spring is not needed. I'm not sold on his answer, do any of you have thoughts on this?
Old Mar 31, 2018 | 07:44 PM
Big2Bird's Avatar
Big2Bird
Delco lists two lower hoses. One has the spring, the other does not.
OR, buy this:
https://www.ebay.com/itm/54-55-56-57...19.m1438.l2649
Old Mar 31, 2018 | 07:46 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
been a real long time since the spring was
found by me in a lower hose.
i always reused one if it had it.
funny thing is my 95 cad northstar motor has one.
i would like to use them but like you say, ain't there.
Old Mar 31, 2018 | 08:56 PM
7T1vette's Avatar
7T1vette
"Straight" radiator [lower] hoses require the spring. The corrugated hoses do not require the spring. If an unsupported radiator hose is used, it will collapse at elevated speeds (highway speeds), as that is the suction side of the water pump. That will greatly diminish the flow through the water pump [and radiator] and engine will overheat.
Old Mar 31, 2018 | 09:04 PM
PAmotorman's Avatar
PAmotorman
make sure the corrugated hose is not reduced in inside diameter or you could have a over heating problem because of reduced flow
Old Mar 31, 2018 | 09:12 PM
Tim81's Avatar
Tim81
I bought a Gates molded hose so i guess i hope i can put the spring from the old hose into this new one..
Old Mar 31, 2018 | 09:18 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
81 no spring
69 mustang spring hose is shaped the same
as the 81 vette.
Old Mar 31, 2018 | 09:26 PM
drwet's Avatar
drwet
Last time I checked the Corvette Central website they listed two lower rad hoses for 76-82 Corvettes. One with the GM markings and one without. The one with the markings shows a spring in the photo. I would double check with them before ordering.
I have changed the lower hose on my '79 a couple of times over the years. I just take the spring out of the old hose and insert it in the new one. PITA, but doable.
Old Mar 31, 2018 | 09:57 PM
Richard454's Avatar
Richard454
You can find them if you add "mustang" in the search-
For under $10- it's worth the insurance- and might as well do it while you are at it...Having to drain your radiator again- not to mention is a PIA PLUS about $30 in coolant. Does it really make sense to think the newer hoses are that much better??
"9 Cooling myths"
http://www.onallcylinders.com/2016/0...to-avoid-them/
"The truth is, you must have an anti-collapse spring in the lower radiator hose if you have an older vehicle with a conventional cooling system.
Because the lower radiator hose channels coolant to the water pump and engine, it is susceptible to negative pressure and collapse at high rpm. The anti-collapse spring prevents that from happening. One hose manufacturer says you don’t need the anti-collapse spring because it was used only for factory-fill purposes. This has never been true because of the positive pressure on the lower hose during fill.
Here's one for $6
http://www.virginiaclassicmustang.co...OCK-P1416.aspx
Old Apr 1, 2018 | 12:15 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
key words pld conventional
hoses are better. thicker and don't swell or
split like they used to
pressures are higher in rads.
15lbs is now 18lbs
apparently mustang still has them avail
confirms my experience.
learn anything?
Old Apr 1, 2018 | 06:31 AM
Tim81's Avatar
Tim81
15lbs is now 18lbs
learn anything?
Still taking it all in. I guess I should own a Mustang. 👍
Old Apr 1, 2018 | 08:25 AM
Street Rat's Avatar
Street Rat
Corvette Central has the hose with the spring. I put one on my car.
Old Apr 1, 2018 | 09:19 AM
Tim81's Avatar
Tim81
I wanted to get the hose locally so I got one without the spring. Hopefully I'll manage to put my old spring into the new hose. If not I'll have to go to a vendor..
Old Apr 1, 2018 | 10:13 AM
Shovels and Vettes's Avatar
Shovels and Vettes
I don't buy this theory that springs are required. If this was so, then why do the mass produced hoses comes without them.....if there was truly a failure of the product, then a spring would be installed. My hose was purchased specifically for my car, and it did not come with a spring. I have never had a cooling issue. Something has changed since the original design included a spring.
Now if the "high" RPM meaning maintaining 6000 RPM for hours, maybe that would be an issue....but where do we do that? Not on public roads or highways.
Old Apr 1, 2018 | 01:22 PM
Tim81's Avatar
Tim81
Thanks for the input, I'll still feel better if I can get the old spring in the new hose...
Old Apr 1, 2018 | 01:33 PM
drwet's Avatar
drwet
Pretty sure the spring won't do any harm and I feel a lot better knowing its in there. If I ever have a cooling issue, its one thing I know isn't the problem.
When I first fired up the 427 the upper rad hose would collapse when I reved the engine. I was worried about it at first, but finally decided it was the result of air in the system. It went away after the system was fully bled. I posted a video to Youtube. I can easily imagine the same thing happening to the lower rad hose.
https://www.youtube.com/watch?v=fmsU...ature=youtu.be
Old Apr 1, 2018 | 01:38 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I would. Certainly does no harm, especially if you just reuse the old one.
15lbs is now 18lbs
learn anything?
Got me thinking a little. Since these systems are under positive pressure, how would the bottom hose collapse? Most of the system is inflexible and filled with liquid. For the bottom hose to collapse, the pressure difference would have to be greater than the said 15 PSI and the fluid would have to expand somewhere else. The upper hose maybe?
To Lower Radiator Hose no spring?
Old Apr 1, 2018 | 03:46 PM
HeadsU.P.'s Avatar
HeadsU.P.
Its not so much the pressure, its the suction on the hose that collaspes it. The waterpump inlet puts a tremendous negative suction on the lower hose at speed. The coolant from the radiator can not fill the lower hose fast enough. Thereby collaspsing it.
If you don't think it happens, put a Go-Pro camera on the hose and go for a ride on the highway.
Old Apr 1, 2018 | 03:59 PM
C6_Racer_X's Avatar
C6_Racer_X
You can reuse the spring, provided it hasn't corroded to the point where it's falling apart.
The springs are also available separately. Search on your favorite search engine, or fleaBay or Amazon, or your favorite online "speed shop" (Summit, Jegs, etc.). Earls Performance makes some generic ones. The ones for a Ford Mustang should work, or the ones for the late 1960's Pontiacs.
Old Apr 1, 2018 | 09:40 PM
Big2Bird's Avatar
Big2Bird
The longer the hose the more the issue. The old Caddys and Montes with the long azz hood and the long azz hoses were notorious for this.
