1970 AC R12 or R134
You can switch over to 134a if you want; but you have to purge/clean the entire system and use a different lube oil. Also, the original system using 134a will not be as efficient. And I think there are parts of the system that have to be recalibrated or have parts swapped for it to work at all.
I live in FLORIDA for the last 21 years now, and if my 'careless' changes worked for 21 years here, I suggest it's no biggie......134 oil, and charge it.....
Lars
Lars
If your charging a system from zero, you want a vacuum pump and a scale. Weigh the exact amount you use and fill it to specs.
Lars
Here is everything I put in new. Everything purchased from Paragon.
2473 AIR COMPRESSOR BELT-CUT STYLE
5770 HEATER CORE, W/A/C-REPLACEMENT STYLE-HEATER CORE, W/A/C
5785 AIR COMPRESSOR MOUNTING BRACKET-AIR COMPRESSOR MOUNTING BRACKET
11743 Blower Motor-BLOWER MOTOR
11752 A/C Evaporator Drain Tube Kit-A/C EVAPORATOR DRAIN TUBE
11766 A/C CONDENSER-A/C CONDENSER
11768 A/C RECEIVER DRIER-A/C RECEIVER DRIER
11772 A/C LIQUID LINE - W/ S.B.-A/C LIQUID LINE - W/ S.B. 111774 A/C Condensor Inlet-A/C CONDENSER INLET W/HOSE PROTECTOR
11775 A/C Dryer Outlet w/ Hose Protector-A/C DRYER OUTLET W/ HOSE PROTECTOR
11771K A/C MUFFLER & HOSE ASSEMBLY-A/C MUFFLER & HOSE ASSEMBLY
I have driven the car, but the compressor is not hooked up.
I looked and can't find out about the compressor, I will contact the auto parts guys tomorrow or Wednesday.
A compressor does not care what Freon is in the system. However the oil that a compressor comes with may also dictate the “Freon” that is used.
If you are lucky it came with ester oil in the compressor as this is compatible with both 134a and r12 oils. Even if it didn’t just don’t mix PAG with mineral oil. It’s the oils that are not compatible. The various “Freons” do not care, that being said, r12 will not carry PAG oil well.
I would use ester oil (POE) to insure good oil carrying capability of either Freon and compatibility with any existing oil in the system.
I run ester in my system and a mix of r12 and 134a currently.
Office tube systems are sensitive to the size office tube used. The ford blue office is a good efficient one for 134a systems.
Lots of cooling air through the condenser is of paramount importance as well. That’s where the heat exchange takes place. You can’t ever get too much air through the condenser. Electric cooling fans are very good at this.
The new units have the green o-rings that work with either freon.
The 134 hoses work with R-12, but not visa versa.
If you flush the old cond. out properly, and use the correct parts, the 134 will work at 80% of R12 charge, but not as well.
That system was designed around R12 Freon. R134A uses a parallel flow cond.
You can go either way, but I changed my 81 over to 134A, and it sucked. I converted it back to R12, and it works great. I think it cools 10-15* cooler.
YOUR call.
In any event, you need to know if the compressor came with oil in it and what kind of oil it is.
PAG oil has a distinctive smell. Go buy a bottle of PAG and give it a whiff.
Now open you system at the compressor and give that a whiff. Same smell? There’s your answer.
Second question is still how much oil was in that compressor. The full charge?
When you put it on did you drain oil out of the compressor?
In my experience the compressor comes with an oil charge in it. Then usually you drain that out and put in fresh oil, sometimes all in the compressor and sometimes half in the filter dryer. In either case it is necessary to know the quantity of oil in the system.
