Wiper/washer switch
Old Apr 12, 2018 | 12:55 PM
kansas123's Avatar
kansas123
Default Wiper/washer switch
I wonder if someone out there has had a look at the insides of the dash wiper/washer switch? I took mine apart to see if I could get it to work properly (only had high speed), but in the process, a part fell out of it and I don't know for sure where-eth it goes. Thanks.
Old Apr 12, 2018 | 02:56 PM
7T1vette's Avatar
7T1vette
I think that is called an "OOPS!". Replacement part time....unless you are good at puzzles.
Old Apr 12, 2018 | 04:42 PM
kansas123's Avatar
kansas123
rats, the replacements don't hold a shine to these oems
here is a larger picture of that part that fell out. Brass, about 1/16 dia, 3/16 long. Still nogo you reckon. I hate to let go.....
Old Apr 12, 2018 | 05:46 PM
DUB's Avatar
DUB
Logic would tell me that the dome would go down and be visible. And I would guess that it is spring loaded also.
And the contact surface of the portion of the switch that this 'dome' would contact show show signs of decades of being in a specific position. Because if the domed part were inverted...then the hollow tube end should have a worn spot on it or left a wear spot on the part.
DUB
Old Apr 12, 2018 | 09:59 PM
7T1vette's Avatar
7T1vette
I'd need to see the mating part; but that 'bullet' appears to be a spring-loaded electrical contact. Or, it could be a positioning detent. Either way, the point should be outward with spring behind it.
Did you find the spring that shot out with the 'shell'?
Old Apr 13, 2018 | 06:49 AM
kansas123's Avatar
kansas123
I could not find a spring. I will see if I have a pen around here that has the right diameter spring and use part of it. Thanks
Old Apr 13, 2018 | 04:40 PM
kansas123's Avatar
kansas123
Found a spring put the spring in put the switch back together the switch would not move without getting stuck eventually broke the casing of the switch and now I get to buy a new Switch the end. but that's okay.
To Wiper/washer switch
