Front wheel bearings
Old Apr 26, 2018 | 10:36 AM
baby blue 78's Avatar
baby blue 78
Default Front wheel bearings
My 1978 in for inspection and the mechanic says the front wheel bearings need re packed. too much play in wheel. He checked and these were done 2 years ago and total mileage on the car only 900 miles since.???? He is not sure what is going on but should not need to replace or work on them with just 900 miles.
Any ideas?????
Thanks Mark
Old Apr 26, 2018 | 10:46 AM
Alan 71's Avatar
Alan 71
Hi Mark,
I'm not sure how re-packing the grease in the bearing can affect the 'play' in the wheel.
I'd think it might be that the spindle NUT wasn't tightened properly, or that the spindle bearing surface is worn... but don't see how new grease helps either of those situations.
Regards,
Alan
This is the spindle nut.
Old Apr 26, 2018 | 11:02 AM
MelWff's Avatar
MelWff
I think you have to be clearer, when you say wheel, do you mean the steering wheel or the road/tire wheel?
Old Apr 26, 2018 | 11:25 AM
A88FXRS's Avatar
A88FXRS
have him get someone who knows the correct procedure for adjusting spindle nuts.
Old Apr 26, 2018 | 12:03 PM
JoeMinnesota's Avatar
JoeMinnesota
It's not a big deal. I agree - should go thousands of miles before needing to re-look at front wheel bearings. If THEY did it last time, ask him why it only lasted 900 miles. If they were done 900 miles ago, maybe someone didn't install the spindle nut properly.
I would pull (or have pulled) the bearings and look them over. Replace if there is an issue. After greasing new replacements or a re-pack, tighten the nut on snug (spec is something like 12-15lbft) and then back off far enough to line up the hole for cotter pin. Pin it and you're done.
Old Apr 26, 2018 | 12:14 PM
HeadsU.P.'s Avatar
HeadsU.P.
Alan, did you park your car in the diningroom again? (flooring)
You gotta cut that out.
Old Apr 26, 2018 | 03:48 PM
lakerider57's Avatar
lakerider57
His car is definitely clean enough to park there !
Old Apr 26, 2018 | 04:17 PM
theandies's Avatar
theandies
How is he checking the bearings? Is he grabbing the tire (while on the car) top and bottom and wiggling? If that's the case it could be your ball joints making it feel like a loose spindle.
Old Apr 26, 2018 | 04:18 PM
theandies's Avatar
theandies
Old Apr 26, 2018 | 09:17 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Kids today don't realise that there should be some play in the old fr wheel brgs.
Old Apr 26, 2018 | 09:32 PM
super charged's Avatar
super charged
Better loose then tight.
Old Apr 26, 2018 | 09:57 PM
Sayfoo's Avatar
Sayfoo
[QUOTE=Alan 71;1597079006]Hi Mark,
Regards,
Alan
Agree.
You might need a new mechanic.
FYI The spindle threads are fairly course and it is sometimes not possible to get the correct "play" if the threads or the nut are a little worn. A new nut or surfacing the old nut may help.
Old Apr 27, 2018 | 01:18 AM
7T1vette's Avatar
7T1vette
Your "mechanic" is just trolling for more business. You can repack the front wheel bearings and properly adjust the free play in each hub yourself...if you can jack up each wheel and you have pliers and an adjustable wrench (and a lug-wrench to remove the wheel nuts).
Unless you find visual or mechanical problems when you pack the bearings, one morning will get that job done on both wheels. I suggest that you use synthetic grease instead of the stuff specified over 40 years ago.
Old Apr 27, 2018 | 04:29 AM
Haggisbash's Avatar
Haggisbash
Were the bearings installed genuine quality items? There have been counterfeit bearings found so I would be inspecting them to make sure that that they are okay. Shouldn't need repacking or adjusting so soon if the bearings are okay and were installed correctly first time round.
Old Apr 27, 2018 | 01:11 PM
MelWff's Avatar
MelWff
baby_blue_78 has posted about 7 different questions on this site, always gets lots of responses, and never responds back to the suggestions we provide,
Old Apr 27, 2018 | 02:05 PM
HeadsU.P.'s Avatar
HeadsU.P.
Another Troll perhaps.
Like the one before: "how do I get 1,000 HP out of my L48?
Old Apr 27, 2018 | 09:41 PM
Sidneyhop454's Avatar
Sidneyhop454
So there should be a little play when rocking the tire, top and bottom? Mine has a little and just bought new bearings to replace them thinking they were worn.
To Front wheel bearings
Old Apr 27, 2018 | 09:44 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
mechanics comments seem in line with finding loose bearings.
should be inspected and regreased.
Old Apr 27, 2018 | 10:49 PM
7T1vette's Avatar
7T1vette
This mechanic stated that the bearings needed to be repacked...and the wheels were still on the car? If he had indicated that the bearing free-play was excessive, I might think he was O.K. But, if this 'story' is accurate, I wouldn't go back to him.
[I don't know how to tell how well the front wheel bearings are greased by testing the free-play....]
Old Apr 27, 2018 | 10:51 PM
Sayfoo's Avatar
Sayfoo
Some times it's very hard to get them exactly right. When you pin the castle nut, sometimes 1 slot tighter is too tight and 1 slot looser is too loose. A little loose would be the better choice. Other than that, you can try a new nut, or machine the washer or nut face or get a thicker washer, etc.
