TCS Delete
Old May 3, 2018 | 09:07 PM
MBrianB's Avatar
MBrianB
Default TCS Delete
Have a '72 with ZZ502 and TH400. It's a new build.
How do I wire a TCS delete?
What should remain connected?
What should be jumped?
Do I just run the kick down at the go pedal to the trans?
Old May 4, 2018 | 12:09 PM
ezobens's Avatar
ezobens
TCS (Transmission Controlled Spark)?
Nothing to wire if you're deleting it-
Just run a vacuum hose from manifold vacuum to the vacuum modulator on the trans and you're done. You can unplug and remove the TCS at that point with no issues.
Kick-down I would wire just as the factory did- Which I believe was a switch mounted to the gas pedal bracket?
Old May 4, 2018 | 02:37 PM
MelWff's Avatar
MelWff
TCS has nothing to do with the transmission vacuum modulator.
It controls vacuum advance and prevents it from occurring in any gear other than 3rd in a TH400.
Run the vacuum line from the distributor vacuum advance to a a source of manifold vacuum.
Old May 4, 2018 | 10:34 PM
7T1vette's Avatar
7T1vette
Correct.
Old May 4, 2018 | 10:37 PM
ezobens's Avatar
ezobens
My bad, I had modulator on the brain instead of vacuum advance.
It’s probably been 40 years since I’ve seen a TCS valve.
Sucks getting old.
Thanks for clarifying.
To TCS Delete
