That looks like the connectors in the main power wires running from the under hood harnesses to the starter solenoid. One side goes into the under hood harnesses, the other sides runs to the solenoid, right?
If yes, then that is a fairly common connection to fail. A common way to fix it is to cut-out the connector and directly connect the wires instead.
I doubt those connections melting were caused by the alternator since they commonly fail on a car with a stock sized alternator.
Also, that isn't a connection I'd expect to handle 100A for very long or safely at all for that matter. That terminal type simply isn't suitable for 100A of current. I wouldn't even expect it to be suitable for 63A continually.
75% SOC should still be about 12.3-12.4V give or take. Also at 75% SOC, the internal resistance will not have changed much from the 100% SOC internal resistance either. It certainly won't be anywhere close to 1.3 ohms.
Old battery lots of plate sulfation and grid corrosion. A brand new battery certainly not. Maybe 100 milliohms or less on a new battery, but then it's not going to be dead is it, or if you ran it dead with the headlights it's going to recover quickly, even without the alternator, which again, is not a battery charger.
Voltage is under load not free voltage. Even a 0% SOC battery is between 11 and 12 volts with no load.
thanks everyone especialy dubz & lionel i took those wires & connected them together directly with a crimp connector & duct tape the hell out of them.
as for the alternator i think imma go with around 80 range cause maybe in the future ill add more led lights in & around the car.
p.s. i forgot to mention my horns dont work at all so im going to eliminate them & adding truck or train horn. not sure if that's gonna determine alternator amps
p.p.s. good idea REELAV8R "parallel wiring" 🤔
Reason: spelling
I wonder what is the definition of a high output alternator is??? That can seem to be subjective. I guess it is an alternator that exceeds what the manufacturer uses when building the car is considered that.
So I am guessing that if a 105 amp alternator was used when building a Corvette...that would not be considered a high output alternator....or maybe it does.
