Another won't start when hot issue
Extra wires added and hooked up in advance for a diagnosis is smarter here. You do not need anything huge, just some small wires about the same guage as the purple "S" terminal wire. One connected to the battery lug on the starter and the other connected to the tiny "S" terminal. Leave everything else in place. When the car is hot and not starting, you can make sure it is out of gear then short the 2 wires together (Use a remote starter switch if you have one). If it does not crank, the starter has a bad solenoid at a minimum.
I have driven cars with issues like this up on my wood ramps so I can slide under car and get the starter off in relatively quick time and bench test it while it is still hot. Yes...this isn't one of the most pleasant jobs I have had to do. But sometimes it is needed to be done. Working around and with parts that are HOT.
I also see validity in the timing be way too advanced causing it to not want to crank up when hot. I guess I read into the first post that the starter was not even wanting to engage and try to crank the engine.
DUB
DUB[/QUOTE]
thats how i read it......no cranking at all. OP is that true?
Also note these may need to be real jumpers, i.e. with heavy cables, not skinny booster cables. Since you're looping up one cable and down the other they'll add a lot of cable length between the bat and starter so they need to be low resistance. The cheaper booster cables may have too much resistance when looped like this and cause too much voltage drop to allow the starter to crank even when cold.
I'm collecting parts for my 496 and probably over researching each part and componant that is going into the build.
1. My research told me to stay away from the mini starters as they don't do well with heat soak and that nothing works better than a good OEM type starter with a heat shield.
2. I had a battery ground cable that looked to be in good condition, but was heavily corroded under the insulation and was not conducting well. It may help to conduct continuity and resistance checks on your ground cables.
The current draw then through the jumper to the starter is significant. I have seen on multiple occasions people trying to jump start a car with booster cables and not get it to crank. But when I hand them my set of true jumper cables the car will crank without a problem. Likewise, I've seen situations without a crank on a single set of cheaper cables be able to get a crank when two sets of cable are doubled up. I learned this when playing with cars in my grandfathers garage when we couldn't get the flathead in a 32 Ford Roadster cranking over. It was a 6 volt system which draw twice the current 12 volt systems do for the same power. So trying to boost it with charger set to boost on 6 volts required heavier cables. And I saw it again in the oil field trying to start small diesel generators off our car batteries. This is a case where size may matter.
It is not an issue of heat. It's and issue of wire resistance due to the combination of higher resistivity (a cable half the diameter has 4 times the resistivity) and length (a set of jumpers may be 10' long and this setup will run out one and back through the other - so 20' maybe). Couple that with hundreds of amps used to crank a starter and the voltage drop in the cables can become factor. Making a short hop from the solenoid isn't a big deal as it's just a few inches. So a small cable can manage it for a short time, though it's going to get hot really quickly. It's also the reason why a steel screwdriver of moderate size can work even though the resistivity of steel sucks compared to copper.
Lastly, note that I said in the post the test "may" need good cables. My concern was that this could be tried and result in no cranking and lead to decision that it's a bad starter when it was actually the solenoid failing due to heat. If this is tried and it doesn't crank, I'd recommend trying it again with heavier cables or a double set (though that would become awkward) before scrapping the starter.
now i suppose if i had a failing mini starter and replaced it with a full size starter and heat shield i would be singing about the glory of full size starters and heat shields
Connect a jumper cable from the starter frame (or a bared portion of the front starter mount, if it is still installed) to the negative terminal on your battery. Then try to start the engine. If it starts (when it would not immediately prior), then the ground circuit for the starter is KAPUT! Whether it is a 'rotten' wire inside the insulation, a bad solder/crimp joint at a terminal, or poor contact between a ground wire terminal and mating surface doesn't matter. Success with that test is telling you that if you find the fault[s] with the starter ground circuit, the problem will be fixed.
So, is running a jumper from battery negative to the body of the starter too much to ask?
, have things changed from 40 years ago when my mud soaked brother started the his suburban with a screw driver to jump from the solenoid's battery cable to the starter battery input? My understanding back then was that it was the spin up of the starter that drove it to move the shaft forward so its drive gear could engage the flywheel. Was that incorrect? Likewise on small aircraft engines today (which haven't really changed since the 1940's) I know that if it cranks and doesn't start that the starter will stay engaged with the flywheel behind the prop. It doesn't pull back because of a control circuit. It won't disengage until the the engine actually starts. But I haven't dealt directly with starters in a long time, so if they have changed it's good to know. Likewise, if I've been wrong in my understanding for 40 years, well that's good to know too. Thanks,
, have things changed from 40 years ago when my mud soaked brother started the his suburban with a screw driver to jump from the solenoid's battery cable to the starter battery input? My understanding back then was that it was the spin up of the starter that drove it to move the shaft forward so its drive gear could engage the flywheel. Was that incorrect? Likewise on small aircraft engines today (which haven't really changed since the 1940's) I know that if it cranks and doesn't start that the starter will stay engaged with the flywheel behind the prop. It doesn't pull back because of a control circuit. It won't disengage until the the engine actually starts. But I haven't dealt directly with starters in a long time, so if they have changed it's good to know. Likewise, if I've been wrong in my understanding for 40 years, well that's good to know too. Thanks,Open up a starter. There is a plunger piston inside the solenoid. The electrical magnetic field in the outer part of the solenoid causes the plunger to move forward like a piston in a bore. The plunger is connected to a lever so that when the plunger moves, the lever pivots on a fork which slides the bendix gear into the flywheel. Once the plunger reaches the end of its stroke and the gears are meshed, the last part of the stroke strikes a button in the end of the solenoid that makes an electrical contact which sends power to the big windings in the electrical motor. The electrical motor then turns, and the engine cranks.
The solenoid was a marginal design from the beginning. It just barely works even when everything is cool. GM had design issues many years ago and the fix was a softer solenoid spring to help the solenoid plunger pull in under hot conditions. The resistance caused by heat affects the performance of the electrical windings. Lots of heat and you get the click, but no movement of the plunger piston.
Age, corrosion, taped connections, neutral safety switch, ignition switch, harness bulkhead connections etc also affects the conductivity of the wiring so the plunger does not have enough juice to pull in. Heat stresses the solenoid and the old wiring resistance on an old car adds to the problem.
The screwdriver across the terminals works because it bypasses all the electrical resistance in the harness. Full battery power from the big battery lug to the tiny "S" terminal allows the strongest magnetic field possible in the solenoid. That allows the solenoid to do its job and pull in the plunger piston in, and all the rest works after that.
Bottom line - Adding a relay only helps if the screwdriver across the terminals helps the engine crank. The relay just takes the place of the screwdriver.
Note - screwdriver not original equipment
The first thing I note then is the goal would not be to jump from the S post to the starter via the M post. That would simply give a low resistance alternative path to running through the two windings which have relatively high resistance due to the typical small wire sizes and long windings used on solenoid activation coils. It may well just allow the current a path straight to the starter motor and not actual the drive mechanism (I’ll use the GM circuit schematic terms). Further, as that circuit is hot only with the ignition in start, there would be no voltage at that point unless the key was held in start.
Instead, the jump required is from the B (battery) post to the M post. I’ve conveniently added in a screwdriver to the circuit to show this. Note that not only will this provide power to the starter motor, but it will also energize both the pull in and hold in windings by feeding into the pull in winding at the M post and then out to ground by joining to the hold in winding at the S post. The only difference at this point is that the pull in winding won’t de-energize because there is no 12+ V on the starter switch side to oppose the 12+ V now coming from the M post.
So getting back to the OP’s issue, at this point I see a couple possible scenarios once the screwdriver, jumper cables, remote switch or whatever links the B and M posts.
1 – The starter motor does nothing. Then it’s the motor that has failed when hot because once there is 12 V to the windings it should spin unless there is some switch not shown in this diagram which prevents it from spinning if the drive mechanism is not engaged.
2- The starter spins but doesn’t crank the engine. Then there is something wrong with the pull in and/or hold in windings that shows up when they are hot. This could include a bad hold in ground since, I assume, it takes the power of both windings to move the drive mechanism.
3 – The starter cranks the engine. Then the windings and the starter are working, so the issue would have to be upstream and heat related.
This is all based on looking at just this one schematic. So, if there’s more to it or I just misinterpreted what's there, always a distinct possibility, then I’m open to further education.
I apologize, but I don't see the point of that jump. Jump the battery straight to the starter and it will either spin if it's good on not if it's bad or, I'll add, if its ground is bad, in which case neither the pull in winding or the starter will kick.
