69 Wiring Issue
Old Jun 30, 2018 | 05:40 AM
Kerz's Avatar
Kerz
Default 69 Wiring Issue
Helping my brother with his restoration (Shanghaied, Ha). Incomplete work by others.
New wiring harness and turn signal switch connectors do not match up. Close but will not clip together. 10 pins (6 and 4). As I understand, this is a fairly common problem but it isn't clear on how to modify to make the connection work. Appreciate your thoughts.
Vic
Old Jun 30, 2018 | 06:28 AM
bazza77's Avatar
bazza77
what year corvette is the harness for ?
or some pics of the offending plugs !
Old Jun 30, 2018 | 07:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Who manufactured the harness? Lectric Limited has excellent products.
Old Jun 30, 2018 | 09:31 AM
DUB's Avatar
DUB
Obviously you know that GM used different types of turn signal connectors.
Do you have the original turn signal connector...or one that will plug in???
If it clips in the new harness...just remove the terminals and install them. I run into this issue quite often.
DUB
Old Jun 30, 2018 | 12:08 PM
Kerz's Avatar
Kerz
1969. It will be next week before I can get some pics.
Kerz's Avatar
Kerz
He purchased the wiring from Paragon a few years ago.
Old Jun 30, 2018 | 12:12 PM
Kerz's Avatar
Kerz
DUB
Yeah, I was aware of the different connectors. He has the old vehicle harness but not the old turn signal switch. The new turn signal switch connector will not fit into the old harness either.
Vic
Old Jul 20, 2018 | 10:42 AM
Kerz's Avatar
Kerz
We went back to Paragon. They requested the correct plug from 3rd party vendor, probably Lectric Limited. Problem solved.
Thx
Vic
To 69 Wiring Issue
