Motor Mounts
Old Aug 4, 2018 | 09:33 PM
72 Project's Avatar
72 Project
Default Motor Mounts
Do Big Blocks and Small Blocks use the same motor mounts?
Jim
Old Aug 5, 2018 | 06:10 AM
derekderek's Avatar
derekderek
I know the 3 mount holes on either side of the block are in the same place relative to bell housing flange. So they CAN use the same mounts. The only 350-bbc swaps I have done-so far-involve mercruiser mounts...
Old Aug 5, 2018 | 06:48 AM
Dynra Rockets's Avatar
Dynra Rockets
The short answer is yes, they are the same and interchange
The longer answer is that starting in 1970 there are "safety" mounts for big blocks that are wider at the frame mount. Aftermarket manufacturers now use a common stamping for both and then use a washer (or user supplied washer) as a spacer to make up the width for the safety mount.
See this thread. https://www.corvetteforum.com/forums...or-mounts.html
R
To Motor Mounts
