C3 crate motor
Old Aug 14, 2018 | 09:27 PM
LT1's Avatar
LT1
Cruising
Default C3 crate motor
Has anybody put a high performance crate motor in a C3 over 500 HP
Old Aug 14, 2018 | 10:00 PM
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
Old Aug 14, 2018 | 10:33 PM
lars's Avatar
lars
What's your real question? Are you looking for crate motors over 500 hp, or are you trying to determine the practicality of running over 500 hp in a C3? I have built and installed several engines over 500hp in C3 Vettes, but I have never used a "crate motor" to achieve that goal. What are you asking..?
Old Aug 15, 2018 | 08:23 AM
mobird's Avatar
mobird
LOTS of people have.
As Lars said, what are you wondering about? The drivelines capability to handle the power? What needs to be beefed up? The chassis ability?
Lots depends on what year/rear end is in your car. If you have an iron case diff with HD caps on the half shafts, solid spicer u-joints, and stub axles in good shape, then the car should handle that power just fine as long as you aren't putting slicks on it and hammering it off the line.
If you have an aluminum diff, old u joints, worn stub axles, etc... it will probably shred it up eventually.
If you plan to put a 500 hp motor in your car, it is worthwhile to do some easy basic upgrades to make sure the half shafts and rear end are in good shape.
Old Aug 15, 2018 | 08:41 AM
bfit's Avatar
bfit
First get the brakes working 110% or upgrade then, upgrade the third member and half shafts,
now 500Hp or more it’s your choice
Old Aug 15, 2018 | 10:40 PM
LT1's Avatar
LT1
Cruising
Looking for info on what has to be changed as for the old pan and or oil pump on a JEGS or other rebuilders crate motor.
I was going buy one from ATK and was told it would not fit by their sales person because of the oil pan? I can not find one on line that just bolts in.
Thanks for your reply
Old Aug 15, 2018 | 10:56 PM
LT1's Avatar
LT1
Cruising
Old Aug 15, 2018 | 11:01 PM
Vette5311's Avatar
Vette5311
Default Oil pan
Stock oil pan should fit in the Vette. Vette oil pan will not fit others. You are giving up about a quart of oil capacity is all.
Old Aug 16, 2018 | 12:07 AM
sambrand's Avatar
sambrand
don't skimp on motor mounts, you want to eliminate as much flex as possible from the start.
Old Aug 16, 2018 | 12:27 AM
lars's Avatar
lars
Looking for info on what has to be changed as for the old pan and or oil pump. I can not find one on line that just bolts in.
Any Gen 1 Chevy small block with a stock oil pan will bolt right into a Vette or any other Chevy. There is nothing special about a Vette (hate to burst everyone's bubble...). You can pull a 350 out of a '69 1/2-ton truck or a '72 Impala Station Wagon, and bolt it right into a Vette (as many people did after trashing their Vette engine). The Vette had a slightly higher capacity oil pan, so the Vette engine with the big pan cannot be bolted into the Impala Station Wagon without a pan change.
Also... I'm confused... what difference does the horsepower make if you're asking about oil pan fitment..?
Old Aug 16, 2018 | 08:05 AM
mobird's Avatar
mobird
Any gen 1 block will work. The thing that normally can cause fitment issues in the vette is the intake manifold. As long as you are running a low rise manifold you should be fine. But a taller dual plane like the Airgap or Performer RPM etc... will require a drop base filter.
Old Aug 16, 2018 | 10:04 AM
Fredtoo's Avatar
Fredtoo
Are you looking at the LS type motors, or the original style small block?
Old Aug 16, 2018 | 03:01 PM
cv67's Avatar
cv67
St. Jude Donor '05
x2 betting ATK meant the intake manifold?
Stock oil pump is just fine, nothing fancy needed.
Old Aug 17, 2018 | 12:47 PM
LT1's Avatar
LT1
Cruising
Default crate motor
Thanks a lot. not sure why the jegs sales person and the guy at ATK didn't kown that That was a big help thank again
Old Aug 17, 2018 | 12:50 PM
LT1's Avatar
LT1
Cruising
The salesman at jegs said the crank on a higher HP motor crank would hit the pil pan
Old Aug 17, 2018 | 12:51 PM
LT1's Avatar
LT1
Cruising
Thanks will do that
Old Aug 17, 2018 | 12:54 PM
LT1's Avatar
LT1
Cruising
original style small block Thanks
Old Aug 17, 2018 | 01:47 PM
ddawson's Avatar
ddawson
I would talk to Brandon at ATK for your answers, He goes by Notalent on the chevelle forum. https://www.chevelles.com/forums/139...-web-site.html
Tell him the year of your C3 and that you want to replace the motor and you want to know what will work.
Old Aug 17, 2018 | 01:56 PM
mobird's Avatar
mobird
The HP of the motor has nothing to do with the crank, at least not in that way. Barring some weird combos (short stroke, big bore), a 350 crank is 3.48", a 383 is 3.75", etc... If you are buying a crate motor, it should come with an oil pan that won't interfere with the crank.
To C3 crate motor
