Couple EFI conversion questions
Old Aug 24, 2018 | 03:38 PM
mobird's Avatar
mobird
Originally Posted by lionelhutz
I tend to scrounge GM parts and use them, so I would be using the GM quick connect fittings. But yes, they do make fittings you just have to find them. Try "3/8" hardline to AN adapter" as the Google search term.
Edit - personally, I wouldn't use hose barbs and rubber hose for high pressure fuel line. Don't use rubber braided hose either, stick with teflon or something else similar.
Ok cool, what do people use for that FI rated hose then? I just assumed it was a barb fitting, is there something else that is used? I definitely want to make sure I have a leak-free fuel line setup, don't need any engine bay fires.
Old Aug 24, 2018 | 03:59 PM
lionelhutz's Avatar
lionelhutz
Braided hose, stainless or another braid like nylon.
Old Aug 24, 2018 | 06:00 PM
Matt81's Avatar
Matt81
You can buy an 82 fuel sender off eBay for around $100 and fit it with an EP241 intank pump. What i did on my TBI install and it worked great .Will support my upcoming TPI setup too. That way pump stays cool and no sound of it running. With an external pump, you may head it running.
Old Aug 24, 2018 | 07:10 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Are you installing an EZ-EFI v 1.0 or 2.0?
I was an early adopter of the original EZ-EFI v 1.0; I have had 8yrs of trouble-free driving with it so far. I started a thread about this back in 2009, and there is a lot of good info in that thread:
https://www.corvetteforum.com/forums...-this-yet.html
I posted pics and more details of my install starting with post #260:
https://www.corvetteforum.com/forums...post1575712539
The fuel system I designed and built starting with post #274
https://www.corvetteforum.com/forums...post1575797186
Hopefully this info is of some use to you, and if I can answer any questions you may have, I will try my best.
Bruce
Old Aug 25, 2018 | 05:18 PM
mobird's Avatar
mobird
Bruce
thanks for that link, I skimmed it but ill spend a little more time reading it later!
Question, if I'm replacing my stock (1/4") return line with a 3/8" line, what do I do about the connection at the tank (see pic)? Just keep it a 1/4" connection and then use an adapter to go to 3/8" the rest of the way ? Or does that not do anything for me since the smallest point is still 1/4"?
