Wiring ?
Thx
This is attached to the neutral safety switch
Where do these go?
Where do these go?
AC switch?
Neutral safety switch?
https://drive.google.com/file/d/1LyS...y3FT0lcRl/view
You photos are good but I need to see the ends of the connectors where wire terminals can bee seen. Much like you did in the first photo. So I need to see the color of the wires and the terminal ends.
The last photo..I have no clue on what you are asking about there. Normally when a photo is being taken..the subject matter is in the center of that photo and there is nothing there to see.
DUB
^^^ I'm really not sure about this one. Possibly for the torque convertor lock-up. Maybe to the brake switch?
^^^ I believe this connects to the starter interrupt relay (part of the theft deterrent system). The relay should be on the aft right side of the console panel bracket (just in front of the shift lever).
^^^Pretty confident that this is the connector for the rear defroster. Top left-hand corner of the center console. The plastic pin fits into a recess in the bottom of the switch.
^^^ Diagnostic Check Connector. Wire colours should be; light blue, brown (white stripe), black (pink stripe), white (black stripe), black (white stripe).
^^^^ I'm with DUB on this one. Not sure what the subject of the photo is.
AS for the rest of these connectors...'StDomingos' is SPOT ON CORRECT
DUb
BUT another thought -- the wiring harness that goes to the ECM is JUST for the ECM -- you can remove the whole thing.
