Working on my friends 82 because his passenger side window motor no longer works but his driver side motor does work. After buying a working one off the forum and installing it, it still won't work. Could this be a fuse or a relay that has gone bad? Or is the motor I bought bad?
Did you run 12v to the switch and or motor? If it works then the motor is good.
If not, I would start looking between the door & frame for a broken wire...very common...
You can have a bad switch in the console....or...a broken wire like it has been mentioned going to the motor.
It is easy and simple to find the problem because for your car...there is a connector on the inside of the hinge post that connects to the wiring harness that goes into the door.. So you can check for battery power when you press the switch at that location and then check the connector that plugs into the motor itself.
One wire going to the motor when you press the switch will get battery power...and then when you press the switch in the pother direction the other wire will get power.
