LS Swap - fitting from hard fuel line to braided line
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes
I may be in trouble and not aware of it-- I've been changing steel brake line to AN type fittings for years. Cut the line square, clean up any burrs on the inside and outside, throw the B-nut and sleeve on and a 37* flare. (Cheap Summit Racing flaring tool) burnish the flare and go!
Lars
carriljc (02-14-2019)
Attached are the photos of the 6AN Swedgelock fittings you requested.
ScottEwine (02-15-2019)
Where do we get Swedgelock fittings to use without flaring and attach AN fittings?
Thanks for that scott, i updated my thread with the info of that Earls fitting. Let me know if that is what works for you in the end.
I ended up installing a EFI fuel pump from a camaro (well actually truck as the camaro pump was too short) This should solve any loss of fuel at hard cornering which you then need to by hollymat for which is $$$. May as well go direct to the EFI upgrade fuel pump assembly. I will update my thread now with the info
https://www.corvetteforum.com/forums...rt-list-6.html
The following 2 users liked this post by R6n350GT:
carriljc (02-16-2019),
Scott
Good Morning All,
Here is the current status of my fuel pump/filter/line setup for my 1973 LS3/TR6060 swap. It all went together pretty well. I will probably secure the line from the tank to the pre-filter a bit better with a tie-wrap or two and may replace the rubber vent hose with a braided line as well. Using the Walbro GSL392BX Inline Fuel Pump, WIX 33737 Fuel Filters and Russell 650133 Fuel Filter as the pre-filter. The key for me was the Earl's AT165006ERL Performance Tube Adapter Fitting to transition from the 3/8 steel stock fuel line to the -6 AN braided hose.
I was about 0-5 trying to make up those braided hose end fittings before getting the Koul Tool, after that I have made 6 with no issues.
