Left Rear Caliper getting air in
I am having a consistent issue with the left rear caliper on my 70 Vette with manual brakes. This started last summer when the brake pedal started fading and I thought it was the master cylinder. I changed it out but the problem didn't go away. I thought I wasn't bleeding it properly so after a long time bleeding the entire car I finally capped of both ports on the cylinder and the pedal wouldn't move. That told me it wasn't the master cylinder. I then clamped off the flexible lines at all 4 wheels and isolated the issue to the left rear. I got a remanufactured caliper, bled it and the pedal was rock hard. After driving the vehicle for a few times and one hard braking event the peday was fading and finally had no pressure. It turned out again to be that caliper so I got another remanufactured caliper, bled it, and it did the same thing. Rock hard for few rides until a hard, not real hard, braking event and again the pedal started fading. Actually I forced the hard braking event to see if the problem was still there. I am not sure what to do. I plan to replace the caliper line and the flexible line but I don't really expect that to be the issue. Should I buy a bran new caliper? Is there something I'm missing. Please help as the new driving season is coming soon and this problem is frustrating me.
This is usually caused by excessive runout in the rotor.
https://www.napaonline.com/en/search...h_form-allprod
Tom
