roller cams
Old Mar 3, 2019 | 07:25 AM
worship79's Avatar
worship79
Originally Posted by jb78L-82
Roller cam in my rebuilt/upgraded 355 L-82 now and the ONLY way to go. I am SO GLAD i went roller for all the reasons already mentioned AND it will make at least 30 HP more than a flat tappet cam of similar spec.
My 01 Grand prix with 3.1 V6 and roller cam has 220,000 miles on it now and going strong. Does not burn an oz of oil between 5,000 mile oil changes........ZERO and I drive high speed consistently for extended periods of time, 80-85 MPH, with this V6 and 220,000 miles on the engine with the roller cam.....
What cam did you use?
Old Mar 3, 2019 | 07:27 AM
worship79's Avatar
worship79
Originally Posted by GOSFAST
Ever since we've devised a method to use any hyd-roller or mech-roller cams in most of 100% stock-appearing early SBC builds w/o the need for any cam buttons or any chasing cam end play we've done almost all (recently) using this method.
Makes assembling these units a virtual "walk-in-the-park" now, and most customers choose this method.
Willing to enlighten a roller converter abroad? Looking into purchasing a complete retro-fit kit from comps, this sounds like a money and time (which also means money) saver...
Old Mar 3, 2019 | 08:28 AM
Krystal's Avatar
Krystal
Must be luck of the draw. 185k 5.3 and pretty sure I got a lifter going bad or losing a lobe; had an XFI280 laying around that went flat at 18k, many of the new Gen LSx cars losing GM lobes/lifters.
Flat tappets are always a good option for the guy who just doesnt have a lot to spend ordoesnt care about "all the power"
That must be a guy thing. This girl wants all the power she can get for the $ spent.
I simply can't make a solid argument that would suggest going a little bit cheaper for the flat tappet cam is ever "worth it".
I mean really there is saving a few unnecessarily spent extra dollars and then there is "cheap to a fault". A roller cam is very inexpensive HP and Reliability purchased, IMO.
Old Mar 3, 2019 | 08:42 AM
av81's Avatar
av81
But then roller is the only way to go then the guy puts a carb on top , wouldnt a carb be like a bias ply tire?
Old Mar 3, 2019 | 09:35 AM
jb78L-82's Avatar
jb78L-82
Howards Roller .525/.525 Lift, duration 219/225, LSA110 with AFR heads and10.2 compression in the 355. Makes BIG mid range torque and strong top end HP to 6,000 RPM with 1 3/4 long tube headers......
Chevrolet Small Block 305ci-350ci 1987-1998 Firing Order 1-8-4-3-6-5-7-2
APPLICATION CAMSHAFTS
VALVE SETTING
RPM
OPERATING
RANGE
CAMSHAFT
PART NUMBER
LOBE
SEP.ANGLE
DURATION
VALVE LIFT @ 1.5:1
INTAKE CENTERLINE
ADV.
@ .050”
IN.EX.IN.EX.IN.EX.IN.EX.
HYDRAULIC ROLLER: Fair idle, Performance Street, Nice streetable mid range power. 1800+ stall suggested.
Hyd
Hyd
1500-5600
181145-10
110°
272
278
219
225
.525
.525
106°
Old Mar 3, 2019 | 09:52 AM
Krystal's Avatar
Krystal
Nope!
Now you're talking about something entirely different.
Not only is the conversion to EFI considerably more expensive as up date to modern tech......it's also not as stealth.
For the person who wants the car to remain period specific in it's appearance and how it works a roller cam gives them a chance to add performance and reliability without changing the over all experience of the car as it was originally built.
Old Mar 3, 2019 | 10:04 AM
cv67's Avatar
cv67
St. Jude Donor '05
LOL True...
Sometimes we go flat anyways
Old Mar 3, 2019 | 10:31 AM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
I regret cheaping out on my rebuild two years ago with flat tappet and iron heads and now I'm going with a roller cam and aluminum heads like I should have done to begin with.
Old Mar 3, 2019 | 01:13 PM
av81's Avatar
av81
Originally Posted by Krystal
Nope!
I dissagree with you sir , your the first post mentioning period specific or stock apperance if thats what you mean , most are just saying or pointing out that roller is superior hands down to flat tappet cams , I do agree but at the same time using a carb is the same thing old tec , FI is superior to carbs any type. Yes it cost more!
If the subject was "in keeping with stock apperance" are rollers better I would not mention FI although you could use a tbi style and hide it under a stock air cleaner.
Old Mar 3, 2019 | 05:32 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
This is the roller setup http://www.lunatipower.com/Product.aspx?id=4538 I'm using in my 454 w/trips.....when I had the short block rebuilt......the machine shop liked the choice and feels it will be just fine.....also the thought of no break-in was very appealing....anxious to get it fired-up soon....somewhat expensive...yes.....but worth it for piece of mind in the future....
Old Mar 3, 2019 | 06:37 PM
99 Black Bird TA's Avatar
99 Black Bird TA
hydraulic roller cam over flat tappet.
It's a no contest hydraulic roller. It's better to save up the extra dollars and go roller cam even if someone is budget conscious. A car with a freshly rebuilt engine with a flat tappet cam strikes me a major negative.
I've ran a hydraulic roller cam 389,500+ miles in a 305 91 Camaro. It still ran great when pulled for a LS swap.
Old Mar 3, 2019 | 10:49 PM
kossuth's Avatar
kossuth
Flat tappets are always a good option for the guy who just doesnt have a lot to spend or doesnt care about "all the power"
Lots of reasons it can happen. Not having enough seat pressure on the valve springs will definitely wipe a lobe. Think of a lifter bouncing on the lobe. That bouncing will chip the cam causing it to Pit and it’s all downhill from there. Another reason this happens is with agressive lobes like Comps XRE lobes is not running titanium retainers. Seat pressures and valve train weight are even more critical with agressive lobes like these.
Old Mar 4, 2019 | 09:46 AM
  #33
Jebbysan's Avatar
Jebbysan
Dr. Detroit
When I built my 406 it was get a hydraulic roller or get a new pair of heads......guess which one I did?
I know how to break in a flat tappet cam......and I knew that the cam I chose would break in well without issue as I had used that cam a dozen time dozen the years.
Also with the 3.750 stroke I did not want any cam to rod clearance issues and I have none with the FT.......but a roller I am sure would have hit.
It was a $500 question......my car runs fine and yours will too.......
Would it make more power with a HR? Probably.....but it makes so much power now that until tires and chassis are sorted, it is unable to use it.
Yes the HR is better overall.......every car you see on the road today has a roller follower in there somewhere be it OHC or OHV.......but before 1990...Chevorlet had
built about a billion engines with FT cams......and so did everyone else.
Your call.....but to me it is a money thing.
Jebby
Old Mar 4, 2019 | 09:49 AM
  #34
LenWoodruff's Avatar
LenWoodruff
What roller cam did you use in your L82?
Old Mar 4, 2019 | 10:21 AM
  #35
jackson's Avatar
jackson
VALVE SETTING
RPM
OPERATING
RANGE
CAMSHAFT
PART NUMBER
LOBE
SEP.ANGLE
DURATION
VALVE LIFT @ 1.5:1
INTAKE CENTERLINE
ADV.
@ .050”
Hyd
Hyd
1500-5600
181145-10
110°
272
278
219
225
.525
.525
106°
Is your Howard roller on a steel core or cast core?
-edit-
also, isn't that pn 181145-10 shown to fit 1987 - up with OE roller cams ... same grind likely available for earlier (L82 )block but with another pn.
Old Mar 4, 2019 | 10:44 AM
  #36
jb78L-82's Avatar
jb78L-82
This is my howards roller cam:
https://www.howardscams.com/hydrauli...cams-111145-10
Old Mar 4, 2019 | 11:46 AM
  #37
OldCarBum's Avatar
OldCarBum
Start a new thread on this subject and you may find you could not be more wrong.
EFI is better in some aspects, but if you want more horsepower any engine builder will tell you and the dyno tests will show that a well tuned and set up carb will produce more torque and horsepower every time.
To roller cams
Old Mar 4, 2019 | 01:09 PM
  #38
av81's Avatar
av81
Ya I am sure carbs are the way to go , what size carb is on a Z06? Or Demon ?
Some other interesting comments though for sure about the roller , that gives me something to think about if you can get 30hp by going roller ... I thought I saw a Edlebrock kit with alum heads , roller cam ect that looks like a good deal.
Old Mar 4, 2019 | 01:33 PM
  #39
GOSFAST's Avatar
GOSFAST
The fact that the cam button AND measuring cam end play and shimming the button is eliminated with our setup is a "positive" for assembling these builds!
We supply the tooling to set up these blocks and sell the kits with all the correct pieces to get it done. The one and only drawback is this procedure must be done when all the machining is being done, it cannot be machined "in the car" (at least I wouldn't try it).
The cam and lifter package (only) should be in the neighborhood of $650.00, give or take a few! We use both Morel's and Comp's rerto-hyd lifters, the Comp's are a bit more expensive but many of my own customers ask for these. I've had no issues using either brand so far!
Thanks, Gary in N.Y.
P.S. We stay with the "stepped-nose" cast core cams on most of our 100% stock-appearing builds, this allows for the use of the OEM fuel pump pushrods AND the OEM distributor gears. With this cam setup, our true-roller "Torrington" timing sets, and our modification to the blocks, we get .003"/.004" cam end-play every time. No "hassles" and absolutely no timing cover issues, the cover is no longer in play with the cam thrust-plate setup.
Old Mar 4, 2019 | 01:48 PM
  #40
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I second on the Howards stuff! I have this in my 383 and it rocks!
https://www.howardscams.com/hydrauli...ms-cl110255-12
