Widest tire on a C3
Old Mar 31, 2019 | 02:35 PM
The Phantom's Avatar
The Phantom
Originally Posted by CA_WxMan
For the OP, I run 275/40R18 on 18x9.5" wheels with 5.25" backspacing.
They fit fine on all four corners with offset trailing arms. I think they'd probably fit with a regular trailing arm, if you relocated the e-brake cable.
With a VBP dual-mount setup in back, the spring bolts and the sway bar were very close, but they never rubbed.
This past summer I switched the rear over to Ridetech coil-overs and I'm thinking of going to 295/35R18 rears on 18x10.5" wheels with 6.0" or 6.25" backspacing. Up front I'll probably just stick with a 275, but drop it to 35 series since I plan on doing a bit more autocross this year.
Something like this, a member has this set up for sale ...
https://www.corvetteforum.com/forums...eel-combo.html
Dave
Old Mar 31, 2019 | 06:55 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Are you sure you have clearance for that much backspace? My track wheels are 18x10 with 5.74" backspace and with 295 tyres they need 0.2" spacers (making effective backspace 5.54") to avoid hitting the chassis rail in the rear.
Old Apr 3, 2019 | 11:16 AM
CA_WxMan's Avatar
CA_WxMan
You might be right.
I need to check the clearance between the forward part of the tire and the frame rail. There's plenty of room at the back of the tire, but the frame rail is wider at the front near the trailing arm mount and back to about the centerline of the axle and would be the first part to rub.
I think that decreasing the amount of camber gain will also offer a bit more clearance, and going with a slightly shorter sidewall on the tire will reduce some of the flex and allow me to run it a little closer to the frame.
I'm in the middle of an LS2/6-spd swap right now, but when I get it back on its wheels again, I'll check it out closer.
Old Apr 4, 2019 | 12:17 AM
Metalhead140
You might be right.
The frame at the trailing arm pocket is the tightest point by a fair way (after modifying trailing arm, spring, and swaybar). Some people have modified the frame at that point for additional clearance. If you run your car low and add the static toe in to keep the handling ok then that further reduces the clearance there.
