Tach Cable Grease
Old Apr 15, 2019 | 08:57 AM
loflite's Avatar
loflite
Default Tach Cable Grease
I read Willcox's directions on lubing your tach or speedometer cable. Unfortunately, the AC ST640 is unavailable. What are you guys using now?
Old Apr 15, 2019 | 09:31 AM
HeadsU.P.'s Avatar
HeadsU.P.
You have to be careful of which lube you apply. If its too thin, it can actually wick up the cable and into the back of the speedo dash cluster. This is due to the auger-like design on the cable itself when spinning.
When I had to replace mine, I used gun grease made by Hoppes. Its a thick, clean grease that doesn't melt being the cable is close to the headers.
May be able to find that through Google.
Old Apr 16, 2019 | 06:05 AM
terrys6t8roadster's Avatar
terrys6t8roadster
White lithium grease. T
Old Apr 16, 2019 | 06:37 AM
CrossedUp's Avatar
CrossedUp
Old Apr 16, 2019 | 08:28 AM
stingr69's Avatar
stingr69
Used to be the solution was white lithium grease mixed with ATF but that was a long time ago.
Old Apr 16, 2019 | 09:53 AM
loflite's Avatar
loflite
I ordered some Kable ease yesterday. Can't find it at any local stores. Thanks,
Old Apr 17, 2019 | 12:36 AM
7T1vette's Avatar
7T1vette
Graphite or Moly powder... Gooey lubes are not good for the speedo cable. The jacket can get gummed-up and cause binding. If runny lube, it can wick into the speedometer and damage it.
Best to use a dry lubricant and just put a light wipe on the whole cable. One of these days [or years], there will be an affordable kit for making our old cable-drive speedos into electric driven devices.
To Tach Cable Grease
