drain plug
Old Apr 27, 2019 | 09:27 AM
Barho's Avatar
Barho
1st Gear
Default drain plug
I would like to find the location of the drain plug deferential for a 1973 Corvette
Old Apr 27, 2019 | 03:11 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
There isn't one. Gear oil is sucked out through the filler plug with a tool made for doing this. The same suction tool is then used to refill the differential. A hole can be drilled and tapped to accommodate a drain plug.
Old Apr 27, 2019 | 04:03 PM
jackson's Avatar
jackson
Or the wife's turkey baster
Old Apr 27, 2019 | 04:50 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Use the baster before or after dinner?
Old Apr 27, 2019 | 05:04 PM
jackson's Avatar
jackson
definately after ! ... once she gets a whiff of that sulfur, there'll be no dinner for you.
Old Apr 28, 2019 | 10:10 PM
TimAT's Avatar
TimAT
Before will work, but it'll make the gravy taste funny.
Old Apr 29, 2019 | 11:35 PM
GUSTO14's Avatar
GUSTO14
Look for something like this at your nearby NAPA Auto Parts store...
Just be sure to clean it before using it to refill the differential with new oil... or basting a turkey?
Good luck... GUSTO
Old Apr 30, 2019 | 04:46 AM
7T1vette's Avatar
7T1vette
Removing diffy fluid is made easier by driving at highway speeds for about 1/2 hour. That will warm up the fluid so that it flows much easier.
And, if that little jaunt takes you anywhere near a Hooters restaurant, a few wings might be in order......
P.S. That plug is actually a "fill plug". You put diffy fluid in until it just begins to run back out. Then install plug.
Old Apr 30, 2019 | 07:09 AM
Bikespace's Avatar
Bikespace
Good luck... GUSTO
That's the tool you want. I got mine from Amazon for $15- or so. Buy two, as turkey juice is not an approved differential fluid. If your wife cooks whale, however, you can use the renderings as positraction additive, otherwise buy the correct additive when you change the fluid.
To drain plug
