Help Moron Degree Cam
Old May 5, 2019 | 12:19 PM
derekderek's Avatar
derekderek
Originally Posted by NewbVetteGuy
I tried to measure max lift both over the top of the pushrod for the lifter side AND on the top of the valve retainers themselves- but the valve doesn’t really work with tiny beehive retainers and GIANT comp ultra pro magnums over them...
Ill
put indicator on wheel straight above valve stem.
Old May 5, 2019 | 12:59 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I made a stud that attaches to the valve cover rail bolt hole.......depending on the situation, I can take the reading from the tip of a pushrod, or side of the retainer if it is big enough.
Of course, this is done I and E with light tension springs and I have a solid flat tappet and solid roller lifter as spares to use to check with. I use the .050/.050 method......then check the opening and closing against the card...and Bob's you're uncle.
Jebby
Old May 5, 2019 | 09:23 PM
NewbVetteGuy's Avatar
NewbVetteGuy
I can do that as long as the rocker isn’t on. When the rocker is on IT goes over the stem. If the rocker isn’t over the stem and pushing on the valve there’s not much to measure.
Adam
Old May 5, 2019 | 11:16 PM
suprspooky's Avatar
suprspooky
You can measure max lift off of the retainer as well and sometimes its easier, just keep the indicator plunger parallel to the stem. If you really want to ensure the cam is ground correctly you do it on a surface plate and v-blocks (I had a Cam from Straub that was ground with the lobes 0.010 taller than the Cam Bearing Journals) I still steam when I think about the time and money that cost (didn't find it until the Cam wouldn't install past Journal 2).
Old May 6, 2019 | 12:27 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Had that happen one time years ago.....weird!
JIM
Old May 6, 2019 | 12:31 AM
427Hotrod's Avatar
427Hotrod
Whether it's worth the time or not depends on the ability to get good readings. It's always worth the time...and once you've done it a few times and have the tools that work...it only takes a few minutes and you know what's actually happening. You have a few goofy numbers there...I wouldn't be able to sleep until I knew for sure.
I assume the cam card says it's a 110 LSA?
JIM
