What diff gear ratio?
Old May 8, 2019 | 11:43 AM
cv67's Avatar
cv67
St. Jude Donor '05
6th more for mpg than acceleration...with a 27 or 28 in tall tire 4.11 will be just fine. (wont feel super low)
Old May 8, 2019 | 12:25 PM
c3_dk's Avatar
c3_dk
Originally Posted by resdoggie
2.66 x 3.70 = 9.84
2.66 x 4.11 = 10.93
If you want great acceleration, I'd go with the 3.70.
If you want great gas mileage at cruise , I'd go with a 2.73.
I have a similar built 355 with an M21. I replaced the 3.55 with a 4.11. Glad I did. So does the engine!
Originally Posted by gkull
One of the forum members installed 4.30 rear gearing with his 6 speed because of the .5 OD to make 6th gear usable on the freeways. He actually considered a 4.56 rear end. I have had 4.11 rear end in my 79 Vette since the late 1980's because of OD trannies. It really makes a car fast and fun to drive when you close up the gearing.
I have a 11.5 pound flywheel with a 2.89 first gear in a tko600 and with my 650 hp 427 was really nice even for full powered take offs or just minimal clutch slipping just above idle.
I have 0.63 in 5th gear, 23lbs SFI fly wheel, and have the factory 3.70 rear end.
I'm not going to change my 3.70 to 4.11 BUT if I had less then 3.70 then I would have changed to 4.11, when I installed my 5 speed transmission !
Old May 8, 2019 | 01:38 PM
GTR1999's Avatar
GTR1999
Originally Posted by drwet
I was not aware that 3.90 gears are no longer available. If I had to choose between the 3.70 and 4.11's I would probably go with the 3.70's. I have had cars where first gear was too deep, and cars where first was too tall. I would prefer to drive too tall. If first gear is too deep, its almost useless. You are shifting before you get halfway across the intersection. With that said, 4.11's may not be too tall for your application. I have an 18 lb. flywheel behind my 427 small block, and even with that torque you have to be careful not to bog the motor off the line.
Guess this probably doesn't help you. Sorry.
Richmond may still have 390's but I don't believe they are usa made anymore. The GM 390s are long gone.
Old May 8, 2019 | 05:32 PM
PainfullySlow's Avatar
PainfullySlow
2.66 x 3.70 = 9.84
2.66 x 4.11 = 10.93
Gotcha, and thanks for bringing this up.
Launch ratio. ResDog mentioned it. 1st gear times final drive gearing. Street: low side of 10. 9, 9.2 optimal. Drag strip: around 11. But you don't shift into second at 6500 on the street...
Yep, and thanks for bringing this out to the light. I knew that first gear would be quick and likely not good for much other than roasting tires. I figured with the lighter flywheel it would be ok to just shift early or simply start in 2nd gear.
Originally Posted by GTR1999
Mike,
I would say 95% of the diff's I built for an OD trans were 373's, some 411, few 355. You are wise to match the gear to your eng/trans.
Some notes
Toms has gears made for a 3 series case in ratios
308,336.355,373, 411, 433,456 These are USA made by US Gear. The 370 ratio is not offered as the 373 is stronger. A real 370 gear can be purchased but it will be from another company and imported. 273's are long gone. Richmond had 390s same as the GM performance parts catalog from 40 years ago. I stick with US Gear for good reason.
In addition to ratio you need to address other areas within the diff at your power level. If you are coming to the June 15th seminar I can show you everything you would want to know about these diffs.
I was hoping you would chime in =). I am going to do my damndest to make it to your seminar on the 15th. That also happens to be the day my pool team is playing for the state championship so it will likely come down to timing. I guess it comes down to the 3.73 or the 4.11 if I go with Toms...is there any reason to not buy directly from US Gear? Also as you mentioned, Richmond is still available in a 3.90 which seems like it may actually be the best fit but not sure I want to deal with them if they are a crap company now.
if you are going to the track, yes. for pulling out at traffic lights, 11 will have you hitting second in 1 car length. 9.0 is best driver ratio. 6 speeds are really overkill. they are more for LS engines with 50 year newer computerized engine management to make the engine happy at 1900 rpm's under load.
Originally Posted by Gordonm
I am running a T56 from an 06 GTO with a 3.73 rear gear ratio. 6th gear is .57 and it rarely gets used unless you are on the highway. Around town 5th is good with a .84 OD gear. I am running an LS3 for power. Cam is a mild upgrade from the stock. Pushing around 500HP.
This is exactly what I figured. 5th for most driving, 6th only on the highway.
It helps, and thank you. Personally, I would rather short-shift if I needed to. My main concern is that when on the highway the car is happy and I am comfortable. I can always start in 2nd gear if I need to.
Exactly. 6th is just for highway cruising.
After some digging, it seems that Richmond is the only major company that still offers 3.90s.
Old May 8, 2019 | 06:23 PM
gkull's Avatar
gkull
Have you ever actually driven something with 11 or higher? I have 2.87 X 4.11= 11.7957. You can exceed 40 mph in first gear, so you are not going to be shifting in one car length
It's actually kind of pleasant to take off with minimal clutch slipping bio
Old May 8, 2019 | 07:34 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Originally Posted by cagotzmann
Try it on a simulator first and then you will start to see lower gears at the track are usually faster than higher gears.
eg. My local track I made on a simulator and tested different rear ratio's. The 3.08 was usually the fastest with the T56 magnum ratio's.
So for track days what I look for is reaching the max torque / hp RPM near the end of the straights.
eg. my zz383 rpm ~ 5500 in third gear = 109 MPH 3.08 with 3.73 rear = 90 MPH
so on a straight, if the car needs a extra shift to 4th because I reach a red line and lap times are slower. To goal is to keep the engine RPM in the max torque range and long as possible. High gears shorten the time in the max torque RPM ranges. Unless you have a very flat torque / hp curve which then again shifting costs lap times.
I agree with you, and at the circuit I have mostly run at I think the gearing is pretty perfect, I can run basically the whole track in third, changing to 4th on the main straight. But most of what I'm doing at the moment is hillclimbs, many of the hills are very steep, and getting off the line is an important factor too. With the steepness and high speed at many of the tracks I am slipping the clutch hard off the line and spending a lot of time with the accelerator on the floor - I suspect that a higher ratio diff gear would help with getting off the line on a steep slope and the extra torque to the tyre would probably make the car quicker than the time lost in gear shifts. I have a complete 3.7 centre that I have picked up, and all the parts to rebuild it, so I will build it up and swap it out to see if I prefer it. I am also looking at running taller wheels and tires, both for street use (for the extra ground clearance without adjusting the height) and track use (for the extra tyre footprint) which will negate some of the change in gear, so that's a factor too. I've done some spreadsheets to track all the variables, and I'm going to try it to see if I like it.
Old May 9, 2019 | 04:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
A stock TPI wont get 25mpg with a 3.07 and 6 spd, how on earth is anyone supposed to believe a 400hp anything with a carb is doing the same? Its NOT
OP some may get tired of me posting, but gear it for the cam not the cruise rpm. 6th isnt for acceleration anyways.
Had someone talk me into that almost 30 yrs ago....built 350, 3.08 gear. It was a pooch plain and simple. Liveable rpm on the fwy was no consolation.
Old May 9, 2019 | 04:45 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Good gas mileage in a C3? Wtf? 10 mpg is ok with me and my 450+ hp, 4.11 and M21. Rarely get out on the highway anyway but when I do, 3500-4000 rpm is not a problem. That's how we ran back in the day.
Old May 9, 2019 | 05:29 PM
joewill's Avatar
joewill
let me give you another opinion.. a 4.11 gear with a 2.66 1st gear is a granny gear.. you won't even use it. you will be shifting out of 1st at 5 MPH and you will find yourself starting out in second during normal street use.
Old May 9, 2019 | 06:26 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
I always use 1st starting off and so what if I shift a bit sooner than when I had a 3.55. It's not a big deal like you and some others make it out to be.
Old May 9, 2019 | 06:37 PM
71454Chevelle's Avatar
71454Chevelle
This is not a Corvette, but a Chevelle. I'm running a T-56Magnum with a 2.66 1st gear coupled with 4.56 rear gears and 30 inch tires, it works very well with my engine combo (see sig below). It launches hard and I have plenty of power in the upper rpms (7k rpm) to utilize the lower gears. The 5th and 6th gear ratios are .80 and .63, which translates to a 70 mph cruise rpm at a little over 2200 rpm. The best of both worlds.
Also, As far as 1st gear being too low with a 2.66 first and 4.56 rear gear, IMO, no its not. The lower 1st gear makes it much easier to drive on the street. Easier to get things moving, especially if you have a decent sized cam, larger heads, big intake and carb . First gear is not too short in normal street driving. With tall rear tires it takes a little effective gear out.
Old May 9, 2019 | 11:05 PM
cagotzmann's Avatar
cagotzmann
Yes you can just drive to Canada our gallon is bigger
But with my testing when I first installed the T56 with my ZZ383 I got 27.8 MPG (23.4 MPH US) on the one test I did. Total distance driven was ~ 320km (200miles) It would have been better (more accurate) to empty the tank and use more fuel.
Driving speed was 100-115 kph ~ 62 - 72 mph. Did everything to save fuel , coasting down hills, light a steady throttle.
Then at the track a full day session ~ 250km and 82 liters of fuel. ~ 7.4 MPG (US)
Old May 9, 2019 | 11:10 PM
  #33
cagotzmann's Avatar
cagotzmann
3rd and 4th what track do you drive at. For me 3rd is 60 mph - 109 MPH so most tracks in my area I never see 4th.
Old May 9, 2019 | 11:26 PM
  #34
Metalhead140
Wakefield Park is the name of the track. I'm doing well over 200km/h (120mph) before hitting the brakes on the main straight. My 3rd gear is roughly the same range as yours. Fun track!
Old May 13, 2019 | 04:06 AM
  #35
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
4.11s in both my builds using the F-body T56 with the 2.66 1st gear.
If I want to worry about mpg, I drive my Prius.........lol
In my 67 Camaro with the first aftermarket Super T10s (nodular case instead of the aluminum one) back in early 70's I changed my stock 3.73 to a 4.10.
2.64 1st gear
World of distance when launching.
