Q-Jet question
Old May 26, 2019 | 06:59 PM
ATHANASE's Avatar
ATHANASE
Default Q-Jet question
Here we go again. Another thread about the Rochester Quadrajet carburetor.
Yet, I am far from understanding everything about it.
This is about the original carburetor that came on my 1971 LS5, just rebuilt. It works fine (full power, nice idle, as good as it gets gas mileage, etc...) BUT:
It has a hard time getting back to idle. Tends to stick to 1,500 rpm until I gently tap the gas pedal, even when hot. I thought the cable was not sliding well enough, but no. This is not the problem.
Today, I had a fairly long drive and the outside temperature was 92F. The engine would not go back below 2,000 rpm even when tapping the gas pedal. I checked: The cable was not holding it. I even disconnected the solenoid to make sure it won't prevent it to go back to idle.
I removed the air filter. The secondary air valves were closed. If I pushed them open, the rpm dropped to normal. It looked like the choke was not working properly.
I shut the engine off and left it cool about half-an-hour. Started it again. It was working normally... until it got hot again.
Any suggestion or advice?
Old May 26, 2019 | 10:17 PM
7T1vette's Avatar
7T1vette
Take a look at the location of the gasket and/or spacer under the carb, and the location of the carb (on the studs), as well. It is possible that the primary throttle plates are dragging or getting hung up a bit on the gasket/spacer. Just loosen the stud nuts a bit and jostle stuff around. Make sure the primary plates are operating freely.
There is also the possibility of tightening the nuts down too much. They are only supposed to have a few foot-pounds of torque on them. Too much can warp the aluminum throttle plate.
Old May 26, 2019 | 11:42 PM
cabman72's Avatar
cabman72
The primary throttle plate shaft may also be worn causing the plates the stick also.
Old May 27, 2019 | 10:08 AM
PAmotorman's Avatar
PAmotorman
make sure the advance weights in the dist are not sticking in the advanced position
Old May 27, 2019 | 09:39 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
is your choke connected or disconnected? is the choke pull off working correctly, its the little plastic vacuum piece on the passengers side
To Q-Jet question
