Aggressive Cam and ignition timing
I need some help in sorting some timing issues on my 1975 350CSB carb with MSD and HEI distributor.
Previous owner claims there is a more aggressive cam and high comp pistons mounted.
Now to the issue.
The engine seems to run best with at least 19-20 degrees idle timing (no vacuum). Going lower the engine starts yo spike and going down to below 10 degrees i horrible.
But looking at the total timing it passes way over 40 almost upp towards 50 degrees on higher rpms.
I then thought someone fiddled with the distributor and found the mounted one grey spring and one black spring. I do not have the original springs anywhere and therefore i ordered a mr. Gasket 929G advance kit and will probably mount the silver springs to get a mor narrower span.
But i guess i should stay with the stock 139 weights?
Correct me if I'm wrong here but a milder cam would need moore loose/lighter springs and lighter weights but my more aggresive cam would need more heavier/stiffer springs and heavier weights?
Hopefully the heavy springs in the mr.gasket 929g will get me on track. I guessing i need 20 degree idle and then added 15 degrees mech up to 35 degree total.
(Attached current springs setup i dizzy)
Thanks!
I'd suggest you email (not PM) @lars for his timing papers and go from there. He explains it much better than I ever could.
Because as you say, about 34-36 degree of total is the aim regardless of cam and in my case i needto get the range more narrowed in mech addon.
But you're right that 30 degrees mech seems high... 😯
I agree that 19-20 degree initial would be to high for a standard cam but i thought the more aggressive cams (as mounted) required higher initial timing to run smoothly and that this was common?
So your proposal would be to reposition the mounted cam differently then and stay with the bushings and springs as is mounted in the distributor? So it's not a springthing...
Lars
Lars
Thanks for your response.
Good news that 18-20 initial is ok for aggressive cams, then it was as I expected.
So it seems i need more work than only bushings and springs. It was not the 928G kit i ordered but the 929G for HEI.
https://www.holley.com/products/igni...nts/parts/929G
My local store had the 929G or the moroso 72300 in stock i could choose from.
But it sounds like MSD with Accel HEI which i haveis not the best suited setup for my Cam then?
Welding and grinding seems difficult to get it right.
Marcus
The springs look a little stiff from here. Need to soften the springs to get full centrifugal advance in by around 3000 RPM.
You have an adjustable vacuum advance limiter plate installed so that might come in handy but wait to play with it until after the centrifugal curve is set up right first.
The thing is I have too much advance and i dont want it nor before or after 3000rpm. 😁
Generally you want the springs softer so the centrifugal advance starts to begin moving somewhere around 1000 RPM. If the springs are too soft, the centrifugal advance could begin advancing below idle RPM and that would make the idle unsteady. The springs still need to be soft enough to allow the centrifugal advance to be all the way advanced at or before 3000 RPM. You can mix and match different springs to get it where you want it. The curve should start at around 1000-1200 RPM and be all done by 2600-3000 RPM.
Keep this in mind - the goal is to keep the sum of the initial timing setting plus all the centrifugal advance available in the distributor mechanism equal to 36 degrees on a stock head SBC. If you want more initial, you need to reduce the available centrifugal advance in the mechanism. Must maintain the total of 36 degrees here.
This will make wide open throttle and idle work well.
Once the above has been done, the vacuum advance is connected to a manifold vacuum source.
The vacuum can needs to be fully pulled in (advanced) at idle vacuum minus about 2" so it will keep the idle steady. Example: If you have 13" of vacuum at idle, you want a can that will be fully advanced by about 11" of vacuum. Limit the vacuum advance travel to about 12-16 degrees max.
Total of INITIAL plus ALL AVAILABLE CENTRIFUGAL plus ALL VACUUM ADVANCE not to exceed 52 degrees.
The springs basically set the RPM at which maximum mechanical advance occurs. You want this to occur at or just before 3000 rpm.
The bushings in the weights set the total mechanical advance. If you are getting 30 degrees of mechanical advance, that's too much. Stock HEI is about 21 degrees. Your weights are opening too much, and need stops to keep them in check. Perhaps 16 degrees of total mechanical advance and 20 degrees of initial is correct for your engine. The bushings should let you set that.
Good luck!
to grind it back use a dremal or small rat tail file.
having a higher duration cam requires some tweaking to the stock timing set up to get it to both idle and run well.
next up Is the carburetor. That may need some tweaking as well.
But it seems as previous owner already been there with a weld. If I limit it even more it will be more or less stiff 😏
Added pic below on current setup.
Thanks!
If your advance curve is too long, you will need to shorten the advance stop slot by welding a dab of metal into the end of the slot and grinding it to suit your needs. Here’s how:
Either in your engine or on a distributor machine, determine how long your centrifugal advance curve is: Easiest way to do this is to install a heavy set of springs to assure that the advance is at “0” at your idle speed and then removing the springs to observe the max total advance. Let’s say that initial timing with the springs installed is 10 degrees, and removing the springs puts the timing at 35. Your centrifugal advance curve is 25 degrees long. As an example, let’s say you want to run 20 degrees of initial timing with 35 total: You want your curve to be limited to 15 degrees.
Here’s how to calculate exactly how much to shorten the slot:
- Using a set of calipers, measure the travel distance of the advance stop pin/bushing in the slot. This will be the distance from the side of bushing or pin to the contact surface in the slot. Let’s say this distance is 0.20”.
- Now we know that 25 degrees = 0.20”. How do we find what is equal to 1 degree? 7th grade math tells us to divide both sides of the equation by 25:
- 25/25 = 0.20/25
- Dividing this out we get that 1 degree = 0.008”
- Since we want to shorten our centrifugal advance from 25 to 15 degrees, we want to shorten it by 10 degrees:
- 10 x 0.008 = 0.08”. We want the stroke to be shorter by .080”.
- Measure the total actual length of the slot without the pin in it and subtract 0.08”. This is the new target length of the slot. Weld a dab into the slot’s end, and use a Swiss file or a ball end grinder on a high speed to shape the slot to the new calculated length.
- Put it back together and test it.
Lars
Is your distributor machine live again?
Are you accepting mail-order distributor work again?
- 25/25 = 0.20/25
Lars
