Vibration
I would like to change the cam in the engine I have now to give it a little more lop. When I get the new engine done going to sell the old one to a friend of my
Pick the wrong cam for your style of driving, highway cruising or light to light quickness and you and your engine will be unhappy.
Wrong heads with your cam and pistons is a whole other set of problems.
Depending on your entire setup that new Holley could be all wrong.
Plan every detail before you start purchasing your parts.
Sounds to me like you are still planning this build, and you may want to hold off purchasing anything more until you have a complete set up planned and set in stone.
Another thing to keep in mind is how much hp and torque your new engine will put out.
OEM rear ends won't take a whole lot of hp or torque and you may find yourself upgrading everything from the flywheel back.
Look in any Chev/GMPP catalog at block list ... and see Street Grey Iron blocks are CONSERVATIVELY rated max 350-450 hp.
Suggest if you truly think you'll be at 500 hp ... you have a shop blueprint /check block ... lifter bore alignment, cam tunnel, bores square to crank etc etc.
Suggest, henceforth you skip "skip" ... despite marketing hype, too many sob stories.
'86-up block ... suppose your new Scat crank is for 1 pc rms.
Again the heads you pick depends on everything else in your build.
The big questions for me are always,
1. What are you going to use your car for,
2. What is your driving style,
3. What rpm's will you be revving the engine to, and
4. Where in the rpm range do you want to make the most power?
Answer those before you start planning the engine and drive train.
Examples:
A big loppy high lift cam with an operating range of 4000 to 7000 rpm will kill your low end performance and cause you problems cruising down the highway at 2000 rpm running that 750 Holley.
Large rectangle port heads would work great on my 496 if I was revving the engine up to 7000 rpm's, but useless for my street car that will never run in that rpm range and where an oval port head design will work best.
