HEI Help please
Old Jul 15, 2019 | 09:27 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by mike914
I do not have 12 vdc between C+ and C-
I have zero volts
I do have 12 VDC between C+ and ground in 1st position of key now 11.3VDC while cranking. That's
I called tech support they went through mu wiring and asked me to run a separate ground to batt-.
They claim grounding has been an issue.\I did this no improvement.
They claim unit is defective and i must ask for a new unit.
Waiting on response from retailer.
You misunderstood my suggestion. I was asking you to check that there was 12v (referenced to ground) at both C+ and C- (not between C+ and C-), I just wanted to check the continuity of the coil's primary winding.
If the coil measurements look okay, and the Dwell meter/Tachometer reads zero activity while cranking, that usually points to a bad distributor module (assuming things are wired up correctly). A lesser chance of a bad part can be the pickup/timing coil inside the distributor.
Old Jul 16, 2019 | 01:58 AM
Bikespace's Avatar
Bikespace
Not to pick on you, and I hope you do get your car squared away soon, but there's a reason why Chinese-made eBay trash is so inexpensive. If you want an HEI unit, and don't need a mechanical tach drive, why not get one from a later C3? I have a ZZ4 take-off tach on my 79. Looks stock, and works great after following Lars' upgrades.
Old Jul 16, 2019 | 08:24 PM
mike914's Avatar
mike914
Yes you get what you pay for is certainly the case.
Retailer claimed made in USA
I do need a tach drive and did not want to spend 450.
I bet Some of the "Better" units out there are also made in China
Old Jul 16, 2019 | 08:33 PM
mike914's Avatar
mike914
Hello 69427
I checked ground to C- and C+ and get 12 VDC at 1st on position and around 11 cranking.
Next I hooked up dwell and tach meter
At first key position dwell swings to 6 degrees but does not move at all while cranking
At 1st key position RPM is Zero and does not move while cranking.
I spoke with Tech support
He suggested I run a separate wire from ground on distributor to Battery -
He also suggested to OHM out coil wire
Did both no improvement.
Tech deemed it to be a bad unit
Called retailer and so far they have agreed to take it back and send a replacement
While removing distributor I bought a bump starter boy was that worth the 15 bucks
I indexed the motor to TDC while holding thumb over 1st spark plug hole
Blew my thumb out forcefully and stopped exactly on timing mark
Rotor was pointing at spark plug #1 so I feel I am not 180 off and on the compression stroke.
Curious I ohmed out the coil
Zero ohms between C+ and C-
Open between Center connector and +
5 Ohms between center connector and -
Maybe the coil??
Hope they swap it all out
I will keep everyone updated.
Mike
Boxed up and will ship tomorrow
Hope
Old Jul 17, 2019 | 10:21 AM
69427's Avatar
69427
Hello 69427
At 1st key position RPM is Zero and does not move while cranking. Yeah, looks like there's no voltage swings on the C- lead during cranking. Something is amiss in the system.
Zero ohms between C+ and C- There should be around 1-2 ohms (for an average coil) between those terminals.
Open between Center connector and + Most can coils have one end of the center (high tension) winding hooked to the C+ terminal. I would expect that you would measure 5-10 kOhms between these terminals.
5 Ohms between center connector and - If this coil has one end of the center winding hooked to the C- lead, I would still expect to see 5-10 kOhms between those two points.
Maybe the coil??
Mike
Hope
Definitely some odd resistance measurements at the coil. Respectfully, was the meter range set correctly, and the harness wires disconnected during this?
Old Jul 17, 2019 | 06:31 PM
mongoose87's Avatar
mongoose87
not sure if you're set on having a points replacement, or would be willing to use an HEI, but I used this one:
https://www.ebay.com/itm/231872586498
It worked fine after some normal tuning. You have to run a new (non resistor) wire, but it fixed my issue and seems like less stuff to go wrong in the future compared to a points distributor.
Sure the one you have keeps the separate coil and a bit more stock looking, but it seems like if you cared about that you wouldn't be buying this unit off of ebay to begin with. Personally, I don't always go along with this whole "parts from china always suck" mentality. This stuff has been around for more than 45 years. If it works, use it! There are plenty of american companies that have to cut costs/quality in order to make any money, or they make their product in China and slap the label on in the US.
When i bought my 1972, the seller didn't have the chrome ignition cover, and I believe the larger HEI wouldn't fit under it.
All depends on how original looking you want to be.
Old Jul 17, 2019 | 07:18 PM
mike914's Avatar
mike914
Thanks Mongoose87
I wanted to use the HEI with built in coil but only had 5" of room for the distributor.
Most HEI units are up to 7" in diameter and it would colllide with my air filter.
The unit I selected has a diameter of 4.5" and fits perfectly
Old Jul 18, 2019 | 08:00 AM
mike914's Avatar
mike914
I belive so
1RX on the ohm setting
Coil was removed from car
Old Jul 18, 2019 | 08:22 AM
augiedoggy's Avatar
augiedoggy
Ive been running a cheap ebay tach drive hei setup for 5 years or so now. its the larger cap which does fit on my 74. my original equipment was mostly missing when I bought the project.
Since its been broght up so many times, I would love to know where In the united states they still even make this stuff because much of these brand names like accel and mallory and the like have been bought out and manufacturing outsourced to china by holley or whomever owns the branding rights this week. Almost all of these companies no longer exist as a real stand alone independent company and many no longer even have have true manufacturing plants (and if they do they usually make a very small portion of thier product line here).. Last time I looked I could not find a single new oil filled coil that was made in the usa...
A huge portion of the automotive market is generic rebranded parts. look at autolite... honeywell now outsourced the spark plugs to so many countries the last time I got a set of four for my old vw kitcar they came from 3 different countries and didnt even all look the same although they were the same part number.
Old Jul 18, 2019 | 05:01 PM
derekderek's Avatar
derekderek
i don't think even DUI are US made.
Old Jul 18, 2019 | 07:46 PM
wilcar's Avatar
wilcar
All the more reason to keep your old dual point USA made distributor!! I have noticed that prices on old Sbc and BBC points distributors have been on the rise the past few years.
Old Jul 18, 2019 | 10:12 PM
derekderek's Avatar
derekderek
it has no provision for vacuum advance.
Old Jul 27, 2019 | 10:36 AM
  #33
mike914's Avatar
mike914
Default Updates
Hello And Thank everyone for your advice
I received my replacement coil and distributor this week.
Dropped it in this Morning
Started right up.
Set initial timing to 11.9 at 740 RPM
I'm at 31 at 3000 RPM
I need to re-read Lar's paper to set up the distributor.
Also this is with no vacuum advance yet...
Should I simply add a hose from the top port of my carb to the canister on the distributor?
Mike
Old Jul 27, 2019 | 11:18 AM
  #34
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Started right up.
Mike
You need 5 more degrees of timing at 3000rpm. Did you set the mechanical curve up to be all in at 3000rpm along with choosing the right stop bushing (black,red,blue,silver bushing in the small package). This is important for proper tuning.........also the vac advance can is adjustable so adjust it to pull around 12 degrees at idle. Use a programmable digital timing light and it is easy.....
I have used the China MSD knockoff many times on Hot Rods and they are sold by Allstar performance as well.........I have one in a 54 Chevy truck with a 305 that I built for a friend in 2012 and he still drives it every day..........about 15k miles on it......
Jebby
Old Jul 27, 2019 | 03:14 PM
  #35
mike914's Avatar
mike914
Jebby
Thanks Jebby for your advice
Unit comes with Gray advance bushing 21 degrees
Also ships with Silver advance springs 3750
I had my adjustable timing light on the harmonic balancer and at 3000 I read 31 degrees
I turned accelerator a little more to 3500 and there was no change on balancer.
I purchased the spring kit Lars recommends do you think adding the gold springs would help?
Car starts well and idles well but is slower than my point set up off the line.
Actually runs smoother but its more reserved.
Is this normal?
I hear increasing spark gap may help a bit.
Thank You
Mike
Old Jul 27, 2019 | 03:52 PM
  #36
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Is this normal?
Thank You
Mike
Spark Gap should be .040.....in my experience that works best.
The distributor should have come with springs....use one light silver and one light blue.
Jebby
Old Jul 27, 2019 | 05:04 PM
  #37
Bikespace's Avatar
Bikespace
I'm glad it's working out for you!
If you are "all in" with mechanical advance at 3000 rpm, you likely already have the correct springs installed. Set the distributor such that you are at 36 degrees advanced at the all-in point, and you'll find the extra power. Right now, you are 5 degrees retarded from optimum. That should be enough for a seat of the pants improvement when fixed.
What is the range of your vacuum advance?
To HEI Help please
Old Jul 27, 2019 | 07:31 PM
  #38
mike914's Avatar
mike914
Thanks Bikespace and Jebby
I took Jebby's advice and re-gapped the plugs to .40 and installed the lighter springs
Started right up and idles well.
I am at 12.4 degrees 730 RPM Idle
All in at 33 at 3000 RPM
This is without any vacuum advance
I took if for a long ride
Performed pretty well
No sputtering or stalling
Better off the line and under load
Still needs a bit of tuning idles at 750 shakes a bit more and exhaust is louder.
Should I adjust the all in timing to 36?
Also when I do this is the next step to connect the vacuum?
Will I need too re-adjust the timing after I add in the vacuum?
Mike
Old Jul 29, 2019 | 07:35 AM
  #39
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Mike
Yes......go 36 degrees and hook up the vacuum advance......hook it up to straight manifold vacuum....
Jebby
Old Aug 2, 2019 | 03:20 PM
  #40
mike914's Avatar
mike914
Thanks Jebby
I finally got it running well without vacuum advance.
Idle 730 RPM advance was 18
3000 RPM was 36 degrees
Then I connected vacuum advance from the low port on the carb
I believe it is below the throttle plate and still considered manifold vacuum
I was initially at 20 IDLE
and 56 degrees at 3200 RPM
Dialed it down to 12 at IDLE
Still at 51 at 3200 RPM
Will this much advance hurt my engine?
I cannot hear pinging no dieseling etc.
93 octane gas.
Seems to run fine
What am I doing wrong?
