Top dash removal
Old Jul 16, 2019 | 03:08 PM
Corythecorvette's Avatar
Corythecorvette
Default Top dash removal
Hi all am wanting to remove just the top of my dash for renovating work any tips tricks for easy removal please ...
Old Jul 16, 2019 | 03:33 PM
7T1vette's Avatar
7T1vette
There is no such thing as an "easy removal" of a 40 year-old foam/vinyl dash cap. For SAFE removal, you would need to remove the front windshield to allow easy removal. If you don't remove the windshield, you have to "bend" that hardened, brittle, weak dash cap. It's best to work from underneath OR loosen and pull the driver's/passenger's dash panel outward to gain some access. You can remove dash cap fasteners and pull it outward a bit too. Wish you luck...
Old Jul 16, 2019 | 04:42 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You can go to this pdf it should walk you through everything. I understand what 7t-1 is talking about with the pads being brittle, and it's always a possibility you'll crack it.
On the flip side, rarely do I break one though, and more commonly people are wanting the pad replaced anyway.
http://repairs.willcoxcorvette.com/w...structions.pdf
Willcox
Old Jul 26, 2019 | 04:37 AM
Corythecorvette
Willcox
Thank you both I can't risk the screen being broke so slowly but surely will have to be the way.
Old Jul 26, 2019 | 09:24 AM
Corythecorvette
Dash out , not too hard to remove....
Old Jul 26, 2019 | 10:03 AM
7T1vette's Avatar
7T1vette
I thought you wanted to remove the "TOP dash"....
Old Jul 26, 2019 | 12:04 PM
Corythecorvette
No top dash as you can see it's all one piece ...
Old Jul 26, 2019 | 02:54 PM
0Willcox Corvette
Former Vendor
You didn't post what year the car was and when you said upper everyone assumed it was a 1968-1977 car, this is a 1978-1982 dash pad.
Old Jul 26, 2019 | 04:01 PM
Corythecorvette
I am getting a little worried here then , my UK log book states it's a 1976 car , I have lots of parts due to land from USA carpets and T top weather seals , how can I define exactly the year of the car...
Ps it's my first American car I have restored ?
Old Jul 26, 2019 | 04:19 PM
theandies's Avatar
theandies
If its an early model the best way is to take out the A pillar moldings. You still have to be careful but this gives a little more room so you don't have to bend it too much.
Old Jul 26, 2019 | 04:31 PM
Corythecorvette
Think am in deep doo doo here I ordered weather seals kits and full carpet set for a 76 as per my log book , but the import certificate says it's a 78 will the trims and carpet still fit ??? 😢😢😢😢
Old Jul 26, 2019 | 05:07 PM
theandies's Avatar
theandies
look at theVIN number. Left hand A pillar looking through the windshield then go here.
VIN decoder
Old Jul 26, 2019 | 05:34 PM
0Willcox Corvette
Former Vendor
How about posting pictures of the actual car for starters. Yes if you ordered carpet for a 76 and the car is a 78-82 the carpet won't fit, if the car is a 76 with a 78-82 dash pad then the carpet will fit but you have a plethora of knowledge on this forum so post us some pictures and we'll try to help you figure it out.
1976 floor panels were common to 1976 only, 1977 was different, then 1978-1979, then 1980-1982........So carpet wise it makes a huge difference.
Willcox
Old Jul 26, 2019 | 05:54 PM
Corythecorvette
Willcox
It's a 1978 coupe 25th anniversary.
Old Jul 27, 2019 | 10:46 AM
0Willcox Corvette
Former Vendor
And it's titled as a 76???? If this the case you are going to have issues with the carpets. Post the vin number.
Willcox
To Top dash removal
