Guage replacement
Old Aug 7, 2019 | 03:03 PM
Bad3's Avatar
Bad3
Default Guage replacement
It's been MANY years since I replaced gauges in a C3, but remember the panel mounting points could be fragile and tricky to get back together nice and straight. Is there anything to unhook first, allowing a bit more harness length before pulling the panel? Any dos/don'ts/tips/video links? THX
Old Aug 7, 2019 | 05:25 PM
7T1vette's Avatar
7T1vette
You just need to back off the flanged nuts on studs at the bottom of the gauge bezel (access via the two front access panels on trans tunnel). Then you can remove the side and upper screws into the interior panels, remove the control ***** of the radio and remove the nuts/washers under them. Then you can tip the top of the bezel rearward and ease it out some. The lower studs will slide out of the trans tunnel by pushing bottom of bezel forward a bit then lifting the bezel to clear the studs.
As soon as you can, remove the plastic (or copper) oil pressure tubing from the rear of the gauge. Then you can mark proper location of all wiring an bulbs, then remove them to pull the bezel free.
Change all bulbs (whether they work or not); don't lose the little black "anti-rattle" pieces between plastic gauge lens and gauge backplate; and
MOST OF ALL, test it out after you have everything hooked up again BUT HAVE NOT YET INSTALLED THE BEZEL. If something doesn't work right, you don't want to do it ALL again.
Old Aug 7, 2019 | 07:53 PM
Bad3's Avatar
Bad3
Is there a reasonable amount of wire to the gauges to pull back the panel for rear access after removing the oil line? THX
Old Aug 8, 2019 | 03:26 PM
scottjamison's Avatar
scottjamison
In addition to these excellent points, take pictures along the way. That saved me when I was re-assembling.
Old Aug 9, 2019 | 12:12 AM
7T1vette's Avatar
7T1vette
Yes. There is enough wire to pull the bezel out 3 inches or more. But, as you are pulling the top edge back, look to see how much slack there is in that oil pressure line. If you put that line in significant tension, that 40 year-old plastic will snap. That's not a terrible thing, but it's a PITA to get the new line and compatible hardware to re-plumb it. Just get a little open-end wrench in there and loosen the nut on the line, then remove it. Don't worry about a drop or two of oil that comes out the line.
Now, if you lose track and actually start the car with that line loose...... (not so good). And remember to hook it back up once you've put all the bulbs and wiring back in place.
The comment about taking photos is a good idea. It's also wise to have a copy of the AIM sheet for that "bundle" on hand so you can compare what you really have to what it is supposed to look like. Many a person has just pulled all that 'stuff' loose--only to find out that it has to go back in EXACTLY the same way to get it all to fit!!
Old Aug 9, 2019 | 12:34 AM
Kim72's Avatar
Kim72
While it's out, you might want to consider changing your bulbs to LED's. I have been and can tell you they really make a difference at night. Much brighter. If you're considering it, now would be the time to do it.
Old Aug 9, 2019 | 12:56 AM
JETS C3-C4's Avatar
JETS C3-C4
Are the LED's you used dim-able ?
I have read the LED's cannot be dimmed but not sure if this is true.
Just something to consider if cannot dim them.
________________________
Old Aug 9, 2019 | 01:23 AM
Kim72's Avatar
Kim72
Yes, they are dimmable. Part no: "BA9S-WWHP5". Got mine from superbrightleds.com.
Old Aug 9, 2019 | 06:43 AM
7T1vette's Avatar
7T1vette
Where does it state that those LED bulbs are "dimmable"? Most automotive LED bulbs will dim somewhat with the dimmer control on the lamp switch. But, if you decrease intensity very much, the LED's just turn off. The only way to make them function as intended is to put a PWM (pulse width modulation) dimmer control in the power supply line to those bulbs.
If the SuperBright bulbs are fully dimmable (could be done if the circuitry in the bulb allows it), I would like to know where that is documented (or 'claimed').
Old Aug 9, 2019 | 10:41 AM
Bad3's Avatar
Bad3
I was going to disconnect the oil line at the engine to give a bit more room to move. Of course I'll carefully make sure it's free everywhere. THX
Old Aug 9, 2019 | 02:20 PM
7T1vette's Avatar
7T1vette
Do as you wish. I think you have a [much] better chance of successfully removing the line from a gauge panel which have been protected from the environment and not subjected to high heat levels. But, that's your decision to make.
Old Aug 9, 2019 | 02:41 PM
Bad3's Avatar
Bad3
I was only going to remove it from the engine so I can give myself a little more room to remove it from the rear of the gauge.
Old Aug 9, 2019 | 11:11 PM
ronarndt's Avatar
ronarndt
I have those LED in my 68 convert and they dim. Not sure what you mean by fully dimmable. Mine go from almost dark to very bright.
Old Aug 10, 2019 | 12:46 AM
Kim72's Avatar
Kim72
Don't know and don't really care. All I can tell you is that they are dimmable as installed.
Old Dec 11, 2019 | 02:52 PM
Bad3's Avatar
Bad3
Well, I finally made time to do this and holy crap what a pain in the ***! Even with the seats out I'm having a helluva time contorting myself just trying to see what size socket or wrench fits those 2 nuts! Any tricks that I'm forgetting? THX
Old Dec 11, 2019 | 04:13 PM
Bad3's Avatar
Bad3
You just need to back off the flanged nuts on studs at the bottom of the gauge bezel (access via the two front access panels on trans tunnel). n.
HOLY CRAP the passenger side was a pain! Now the driver's side's even worse with the harness, cable, and steering wheel/column in the way!!!
Old Dec 11, 2019 | 05:14 PM
Peterbuilt's Avatar
Peterbuilt
When you put it back together use coupling nuts.
Old Dec 11, 2019 | 06:03 PM
Bad3's Avatar
Bad3
GREAT idea!!!!!!!!!!!!! Thank you
Old Dec 11, 2019 | 10:21 PM
Richard454's Avatar
Richard454
Here's another idea-
Redoing the way the gauge lights mount is something to do- "while you are at it"
Fellow forum member "Greg" did a nice "How to"
https://www.corvetteforum.com/forums...t-upgrade.html
To Guage replacement
