Air leaking from wheel
Old Sep 20, 2023 | 05:51 PM
7T1vette's Avatar
7T1vette
Yes...it does. ANY patch to that leak is required to be on the INSIDE of the rim.....
Old Sep 20, 2023 | 06:08 PM
CHASHR's Avatar
CHASHR
Thanks and will let you know how it goes. So, if I paint the inside (under the tire), and the outside, is that overkill?
Old Sep 21, 2023 | 07:48 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Yes, because technically, you want the "sealant", in this case the paint, to be pushing into to the "void", by the air pressure, thus filling it, rather than trying to seal against the pressure, if it was painted on the outside.
My recommendation would be to use a product called GE Glyptal, if it's still available.
