Air leaking from wheel
Old Feb 20, 2020 | 07:15 PM
78EAGLE2B's Avatar
78EAGLE2B
Default Air leaking from wheel
I have a very slow leak on the left front tire of my 76, so I popped into a tire shop to have it fixed. The tire guy comes out from the shop and says he needs to show me something. Uh oh. He has the tire/wheel in a tank and shows me where the bubble is originating. It's not leaking from the tire or the bead, but from the middle of the rim. WTF? I asked the guy if he had ever seen that before, and he said that it was not that uncommon. The air was probably coming from a tiny crack or weld, and he recommended a new wheel. So, the tires are B F Goodrich Radial TA's 245 60R15 100S. The wheels are original (I think) Corvette Rallye Wheels with the rings and center caps. Does this sound like the Rallye 15x8 wheel with the 4 1/2 offset to accompany the 245 60R15 TA? If so, I'll order one from one of the catalogs I have. Thanks.
Tom
Old Feb 20, 2020 | 10:01 PM
revitup's Avatar
revitup
Did the leak just start or has it been doing it forever?
Old Feb 20, 2020 | 10:04 PM
MelWff's Avatar
MelWff
It sounds sort of correct except the original wheel has a 4" backspace. Are you asking if the wheel is original, would need to see the markings on the wheel. As far as the tire size, that was never a factory size.
Old Feb 20, 2020 | 10:25 PM
lars's Avatar
lars
In 1977 & '78, the Corvette aluminum wheels were notorious for leaking right through the castings. We would get new Corvettes in on the transporters with flat tires. Leak checks would show that the wheels themselves were leaking - not the tires. Not an uncommon problem at all. Chevy had a hard time keeping up with the warranty demand for replacement Rally wheels, and Corvettes would often sit on the lot with flat tires for over a month at a time. Not surprising at all to hear you have a '76 with leaking wheels.
Lars
Old Feb 20, 2020 | 10:43 PM
GUSTO14's Avatar
GUSTO14
Tom, if you can mark the area of the wheel where it is leaking and remove the tire, check to see if it is a structural flaw or an actual crack. If you can find the flaw/crack, you may be able to weld it. If not and the wheels still seems structurally sound, mix up some epoxy and spread it over the inside of the wheel in the area where the air was escaping.
If you do find evidence of a flaw or crack, do post some pictures of it if you can.
Good luck... GUSTO
Old Feb 21, 2020 | 12:33 AM
78EAGLE2B's Avatar
78EAGLE2B
Hey Mel,
The tire guys could not find any markings for the size. I know, odd. I do know that I need the exact wheel size before I order a new one. I'm taking the car to a legit Corvette shop next Tuesday for a little item, and I'm sure they can tell me for sure.
Lars, it's good to know that this was not some anomaly, and I'm not nuts. Well, I could be nuts, but there was air escaping from the wheel, and from your accounts, happened frequently.
Gusto, a new wheel can be had for around $100., so I think I will do that and avoid all the hassle, knowing that I have a new wheel that is intact.
Rev, I think the tire has been leaking since I acquired it about a year ago. It's a very slow leak almost indiscernible. After not driving the car for a spell, I would check pressure, and it would be at 17 or 18 lbs. So I would just add some air, but that was getting old, needless to say.
Thanks for your responses.
Old Feb 21, 2020 | 06:49 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Can you put a tube in it? End of leak and cheaper than a replacement wheel.
Old Feb 21, 2020 | 07:26 AM
Edward Ackley's Avatar
Edward Ackley
Default wheels
ditto on the tube
Old Feb 21, 2020 | 09:10 AM
interpon's Avatar
interpon
Assume op has steel wheel?
if aluminum correct as pointed out for porosity and can be epoxied or even painted sometimes. Steel check for pinhole weld etc..corrosion non starter.
modern wheels are now helium checked..
used to water submerge, then vacuum air, then nitrogen, now helium..
Old Feb 21, 2020 | 10:27 AM
78EAGLE2B's Avatar
78EAGLE2B
Thanks, I didn't think of putting a tube in. Geez, that could be a very simple fix. It looked like there was a pinhole at the weld.
Old Feb 21, 2020 | 02:43 PM
Tampa Jerry's Avatar
Tampa Jerry
If you go the tube route, make sure you get one designed for a radial tire. Jerry
Old Feb 21, 2020 | 02:57 PM
derekderek's Avatar
derekderek
Goop some epoxy on top of the leak as an interim fix.
Old Feb 21, 2020 | 03:39 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
As Lars posted this was common on the 78-79 wheels which in the old days we'd just spray some enamel paint on the rims and re-mount the tires.... or deal with the warranty.
My own low mileage 78 also was a victim of this... The only issue is that the wheels were replaced before I owned the car but they were replaced by us and we still had the original leaking wheels here.... after I ended up owning the car so I still plan on putting them back on the car.
So... I guess... playing this old school you could possibly clean the rim, get some good epoxy paint and spray the heck out of it... For me I'd just replace the rim if it's a steel wheel. (unless you are trying to preserve the original wheels).
IMHO,
Willcox
Old Feb 21, 2020 | 04:17 PM
KenSny's Avatar
KenSny
Originally Posted by Whoisjohngalt
.....The wheels are original (I think) Corvette Rallye Wheels with the rings and center caps. .....
All this talk about aluminum rims, The OP states he has Rallye WITH rings and center caps. Surely NOT the aluminum wheels of later cars.
Steel rallye wheels are pretty cheap, if you don't care about date codes. For Sale on this site all the time.
Of course if he had provided a picture we would have known for sure.
Old Feb 21, 2020 | 05:24 PM
0Willcox Corvette
Former Vendor
Same thing I said in my last paragraph.
Willcox
Old Feb 22, 2020 | 12:00 AM
7T1vette's Avatar
7T1vette
Just fine the leak starting point on the inside of the wheel and weld of Heli-arc the darn thing. That will give you a NON-leaking original wheel. Any minor difference in added weight will be negated when it is balanced. Why spend a C-note for a replacement wheel when less than $50 will fix the original???
Old Feb 22, 2020 | 10:58 AM
7t9l82's Avatar
7t9l82
I agree weld it. It may work to put some. Epoxy paint on it. That may be just the ticket.
To Air leaking from wheel
Old Sep 18, 2023 | 04:41 PM
CHASHR's Avatar
CHASHR
Default Going to try to paint it
Coming late to this one but so glad it is here. I will use some Eastwood Epoxy paint on my Kelsey Hayes rim. I would ask, and assume, that all air should be out of the tire?
Old Sep 18, 2023 | 05:07 PM
7t9l82's Avatar
7t9l82
Take the tire off the rim!
Old Sep 18, 2023 | 06:16 PM
drwet's Avatar
drwet
I think the epoxy paint fix requires that you paint the inside of the rim.
