TC lock up switch
Old Apr 12, 2020 | 09:50 AM
Quackster's Avatar
Quackster
Default TC lock up switch
1980 Auto - After reading several post about a Torque Converter lock up switch I didn't know if my tranny was a TH350C. Inside the engine bay I found the electric/Vacuum switch and followed each. When I had replaced several Vacuum hoses while installing a PCV system I failed to reconnect a vac. line. I follow the wire down to the transmission and it is indeed hooked up. After driving the vette around town and the interstate I did not notice a drop in RPM while driving only when it actually changed into 2nd and 3rd.
My question is how do you go about checking to see if the switch is bad at the firewall before dropping the trans cover to check the internal switch? You guys have helped me identify several things that needed to be adjusted and I was doing a mileage check ride. Will finish today and post results, but if I can determine if the lock up switch is faulty or not would help me increase the mpg. Thanks
Old Apr 12, 2020 | 02:27 PM
gkull's Avatar
gkull
The lockup solenoid switch makes a click when you apply 12 volts. It's an easy test. The actual lockup clutches can fail in the TC. That can be tested with a manual 12 volt switch. Toggle on when driving level about 55 and see if the rpm drops a few hundred rpm
Old Apr 12, 2020 | 05:04 PM
7T1vette's Avatar
7T1vette
Your description sounds like it is working correctly. RPM drops a few hundred revs when 2nd range and 3rd range stabilize. Lockup should drop out (revert to converter mode) when the accelerator is depressed significantly (ie, going up a steep hill, etc).
Old Apr 12, 2020 | 06:07 PM
Quackster's Avatar
Quackster
I only see a slight drop when it shifts into the next gear holding the throttle steady. Not the several hundred rpms that is suggested. When I give it more accelerator the rpms and speed also increases at the same rate. I will hook up a 12 volt source and toggle switch to observe any difference.
Old Apr 12, 2020 | 06:53 PM
Eric P's Avatar
Eric P
It would have a electrical connector going inside the transmission. I thought the T350 with Lock up came out in 81 ?
To check go steady 55 mph , then gas it a little bit , if rpm go up initially then it’s not a lock up , with lock up rpm will only increase with mph
another check is if rpm is steady with mph then tap the brake pedal should release TCC and gain 200 rpm
Old Apr 12, 2020 | 08:16 PM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
" I thought the T350 with Lock up came out in 81 ?"......Correct. Unless someone changed out the transmission for a TH350C, your 1980 transmission does not have a lock up torque converter.
Old Apr 13, 2020 | 08:36 AM
lakerider57's Avatar
lakerider57
The 1980's did have a TH350C with the lock-up converter.
Richard
Old Apr 13, 2020 | 09:17 AM
Roy W.'s Avatar
Roy W.
My mistake, I was only quoting the 1981 specs from the GM Heritage Center.
Old Apr 13, 2020 | 10:59 AM
Quackster's Avatar
Quackster
I have followed the wire down and they are hooked up to the tranny and also the vacuum hose and found the hose disconnected. After I figure out the easiest and best way to hook up a toggle switch I will check it. Anyone have a hand drawn photograph that will guide me in the right direction.
Old Apr 13, 2020 | 11:09 AM
Roy W.'s Avatar
Roy W.
Sorry for the mis-information on my part. Further investigation revealed the TH350C was introduced in late 1979. My bad........Roy
Old Apr 13, 2020 | 11:20 AM
Eric P's Avatar
Eric P
my 1980 L82 doesn't have a lock up T350 unless it was the L48 or 305 California thing ?
Old Apr 14, 2020 | 10:40 AM
Quackster's Avatar
Quackster
I checked at 45, 55 and 60 mph and tapping the brakes today to monitor the engine rpms, noticed no change. I feel it is not working correctly.
You guys correct me if I am wrong with potential wiring test of the TC lock up switch? I only have 1 wire going into my transmission and I am assuming that I can do a temporary tie in of 12 volts exiting the Elec/Vacuum switch into the wire going down to the transmission. Since there is only one wire to the transmission connector, the grounding is done inside at the TC lock up switch itself. Is this correct? Then from there, all I have to do is drive the car around 55 and 60 mph enable the switch and notice if the rpms drop a couple hundred rpm's?
Old Jun 26, 2020 | 03:43 AM
Corto's Avatar
Corto
In some old post related to lock up someone said that using a dedicated 12V switch to engage the lock up is NOT recomended....
I am not shure why, I am also interested in this.
Old Jun 26, 2020 | 09:29 AM
Eric P's Avatar
Eric P
MY 80 does have TCC , I said it didn't in an early post but it does upon further investigation , here's how a 80 TCC works ….. TCC and Cruise Control use the same 20 amp Fuse that goes straight to the Cruise Control /Brake light switch . Cruise and TCC both get 12Volt power provided the brake is off which is the exact opposite of how the Brake light switch works , hitting the Brake cancels TCC and Cruise Control …. From the Cruise Control/Brake light switch the 12 Volt power goes straight to the Vacuum switch under the hood , providing the Vacuum is between 7 and 2.5 inches of Vacuum the Switch will allow the 12 Volt power to go to the Transmission , Once the power is at the transmission the wire goers to 3rd gear pressure switch , if transmission is in 3rd gear the 3rd gear switch allows the 12 Volt power to go to the TCC solenoid which will Lock Up the Converter ,
Old Jun 26, 2020 | 09:36 AM
Eric P's Avatar
Eric P
Something to check is to make sure your vacuum switch gets Vacuum . TCC uses the same vacuum that the EGR Valve and Purge canister uses , temp has to be above 130 degrees for the Vacuum switch to supply ported vacuum to the TCC sensor , EGR Valve and Purge Valve
To check vacuum sensor hook OHM meter up to both leads , apply vacuum and watch the Meter show continuity when the switch is "ON" between 2 and 7 inches of vacuum , also install vacuum gage on vacuum hose to make sure the vacuum system is working , any leak or bad thermal vacuum switch will not allow vacuum
Old Jun 26, 2020 | 10:12 AM
Quackster's Avatar
Quackster
Thanks Eric, I appreciate the information. I have been put on hold a little while, you know how it is, fix one thing and then move onto another. Waiting to see a Doctor. Will update when I am able to continue the Rockets repairs.
Old Jun 27, 2020 | 12:38 AM
7T1vette's Avatar
7T1vette
The problem with a toggle switch is that you have to remember to flip it off EVERY TIME IT NEEDS TO DROP OFF. That means, when you slow down, or when you need to stop, or when you start going of a relatively steep hill, or when you go to pass someone on the highway, .....etc, etc.
If you leave the L/U clutch engaged when it should be "off", the L/U clutch can easily be damaged, It is not a 'full-power' clutch; it cannot handle a lot of torque. And, if the L/u clutch fails, not only will that clutch no longer work, but it could mean a torque converter replacement if any metallic components in the L/U clutch were to generate any debris.
The L/U clutch can save money on fuel costs; but only if it will drop out automatically when you tap or apply the brake (as a MINIMUM fail-safe).
To TC lock up switch
Old Jun 27, 2020 | 08:56 AM
68blvert's Avatar
68blvert
If you really want to run the lock up from a toggle switch, simply run it in series through the brake switch and a WOT switch and continue throught the 3rd gear pressure switch. Personally, I would just get the factory control system working.
Old Jun 27, 2020 | 10:01 AM
7T1vette's Avatar
7T1vette
What is a "WOT" switch???? If you just run power to the lockup switch thru the brake switch (only), it will engage any time the brake pedal is released....like when you take foot off the brake from a stop light. It would be ON during transmission shifts. hmmmm.......
Old Jun 27, 2020 | 05:48 PM
68blvert's Avatar
68blvert
It would run throught the brake switch, like the factory did it and WOT is a wide open throttle switch to unlock at hummmm well WIDE OPEN THROTTLE...
