A 79 control arm bushing saga using the Lars method
Success!!!!
See the hole looking up into spring..mine intersects the hole ..close enough...holy cow folks upper a arm locator not bottom
I find the instructions in the service manual kind of strange because it shows you the distance from where the metal dives down which is very difficult to see as opposed to the hole that’s there they make no mention of the hole which I find bizarre. It is hard to see but that change in metal is in fact right by the hole in the top which I missed the first time which is why I thought it was the bottom as well.
ALSO theoretically if you do as the manual says.. you should actually cover the hole to some degree as the measurement is from the peak stop to spring stop 0.38 +/- 0.12, and at that point is NOT a drain hole especially if on top
thank you
note, cannot get torque wrench on top ball joint die to caliper hose in way..if i did again..by myself i would remove caliper and MUCH lighter trying to hold that thing and putting it on is not easy..
Get it close so spring loose and in place the attach strap and cable chain etc..
starting ride Height from floor to lip of fender 28 inches after new suspension springs 29 inches, after a successful test drive 28.5 inches. Car like new zero noticeable ride degradation or excessive stiffness..handles excellent...really noticeable over bumps..and when pushing corner really hard it snaps to like on rails but smoother faster..had to really be into turn to get same sensation later in turn originally if that makes sense? Not sure if tighter bushings or spring or all. Hell i thought it drove good before..
lower ball joint one bad, other ok but loose..uppers all good but replaced..slight idler arm movement..probably good...replaced while there.moog springs..
tightening the a arm shaft end bolts..bottom ok..to about 50-60 pounds....no clue if right...uppers were a pita to reach..upper manual says 60 pounds was only able to get torque wrench on one and thats a lot of torque for that small bolt..the other best i could tighten with gearwrench as the front uppers are nearly impossible to access...add to that the car on ground to tighten..took a while..i would say one vein finger torque best i could do.estimate 30? Pretty tight and lock washers.
put all shims back in very slight lean to right but drives fantastic, no hurry on alignment till i find someone capable near me.
i’m going to guess and say that replacing the springs pretty much gives you the exact same Ride height as the OEM I figure my original springs after 40 years maybe dropped a half an inch so I’m very happy with the end results and I’m glad I didn’t cut any I would say that I would bet you based on all the postings that I’ve read that a lot of people mistakenly put the springs in not aligning it with the hole on the upper a arm but the lining up with the hole in the bottom of the a arm which would cause the car to sit up higher..
all in no alignment.~300 bucks
my spring choice 474 pound rate, decision here
https://www.corvetteforum.com/forums...-for-79-a.html
thanks
Lower arms dropped down and springs yanked out:
Removing lower arms:
Uppers and lowers out of the chassis:
Spindles and rotors pulled off as assemblies - no need to disassemble:
Gutted front end after 3.5 hours of work:
30 minutes if air chisel work and the bushings are all out:
It's not pretty, but it's fast and it works:
A flapper wheel on a high-speed cleans up the busing bores just great. Before:
After:
Shafts cleaned up and test-fitted to new bushings:
A-arm bushing holes measured to verify light press-fit of bushings into bores. Any excessive mismatch is taken care of to eliminate problems during bushing installation:
Bushings measured to verify fit on the holes:
Bushings pressed into arms, and cross shafts lube'd up for installation:
Lowers all assembled and ready for installation:
Mounted in the chassis and ready for springs:
Springs installed without a spring compressor by lifting the lower arm up and jamming them into place while lifting the arms:
Done! Total duration start-to-finish: 12 hours (2 short days with beer while watching Jerry Springer "I want my Stripper Ho' baby mamma!"):
After:
Or is it just a cosmetic thing and throwing money away if the mounts are ok?
79 strut rod advice - CorvetteForum - Chevrolet Corvette Forum Discussion
assume you are talking rear not front on this thread.
i'm rereading a bunch of times and watching videos. i want to at least get the orders going in.
see the posts to clean up with wheel and mic the openings.. should not be loose but.. i would think tap in.. the tightening of bolt locks it in.
i suggest emailing lars to get latest papers.. he prefers email which would be latest version. what is posted may or may not be the latest.
