T5 Install PART 2
,The T5 is finally here. It is a -196 out of a 1991 5.0 Camaro with the gears that I was looking for. The seller said there was 70k on it and it ran and shifter perfectly.
I am working on an L31 swap. I plan to take my time during the build. In the meantime, I plan to splice in this T5 as my confidence in my skills to pull the project off grew.
Clutch
My biggest concern now is ordering the right clutch disc. I have a 168 tooth flywheel and a Zoom MU series clutch kit.
https://www.summitracing.com/parts/pft-mu5505-1
My current disc is an 11-inch, 10-spline, 1.125 input shaft diameter. The T5 has 26-splines same diameter. I should get a clutch disc that is 11-inch in diameter ??? Such as: https://www.summitracing.com/parts/ctf-381017 I would prefer a clutch disc with more of a positive engagement; I have a tough time feeling it grab.
Clutch linkage
I plan to use my bell housing and linkage. Here it would be wise to purchase an adjustable pivot ball and a new throw out bearing. I have read that there are different sizes (corvette only) TO bearings and I should be careful. The rest of the linkage and lever should be fine.
Cross member
The cross member needs to be made removable. Here is the bit where I was originally intimidated but my self-confidence grew
. I found a place here that supplies metal plates in 2 - 4 and 6mm thicknesses. My neighbor is a welder for offshore rigs and is confident he can help.In a nutshell, the plan is to buy four square plates, 4mm thick. Then cut out the cross member in a slight \ / . Once out, I will clearance both ends to 8mm and weld the plates in.
Many people have also recommended opening the exhaust holes.
Transmission bracket.
That should be easy enough to fab up something like the below. The important bit will be to make it "shimmable" to maintain the 2 degree drop. The bracket will be made out of 4mm plates as well
To fit here
Driveshaft
I found a company here that can balance... I am sure they can shorten and fabricate too. I'll need to measure the distance from the Muncie output to the carrier yoke and compare to T5-to-yoke.
Shifter
The stock one feels ok, but I am not going through all this hassle just to have a vague shifter feel. There are a lot of quality shifters out there such as the Pro 5.0. I plan to make a bracket to adapt my Corvette shift stick and make it come out in the right place. That probably is tougher than is sounds. Ideally with the reverse lockout made functional, I have no idea how to do that yet.
Pilot bearing
Mine is new and should work just fine.
Trans tunnel
I asked the T5 seller to cut out his trans tunnel for me. I should be able to fab something up.
Reverse light
A simple connector on the case
Speedo
I should be able to transplant the speedo gears from my Muncie. It probably will need tweaking but should work.
Oil
Let's not forget to check the Dexron III level
Misc.
Bell house bolts, trans mount bolts, tunnel clearance, etc. All minor things... but can be a pain in Belgium.
I think, once I get over that bit, it will be downhill from there. My biggest issue is I don't know how to weld worth a damn and part of it is not owning my own rig.I will use same size disc that came with the clutch kit
R&R = rest and recuperation?
Well my vibration woes are compelling me to move forward. I am increasingly suspicious of my M21. Having thrown everything I could to figure it out, I am running out of ideas.
I would have preferred solving this prior to the T5 swap... but so be it.
Next weekend I plan to break out a sawzall... or whatever saw that I can scrounge that’ll work.
HT to @67-427ci I will be using his design for the removable crossmember.
His pics... not mine.
I like the way it is away from asphalt and that little welding is required under the car. I am not sure I will recess the bottom to clear the exhaust.
It would seem to me that a better design would be to have the end portions of the cross-member with a continuous TOP plate and the back-side face only (along with the 4 thru-bolts. That would allow your to install the new member by sliding it over the existing members, then bolting it thru both sets of side pieces to prevent it from moving fore or aft. The TOP plates would then be holding all the weight and distributing it thru the remaining parts of the original cross-member.
Just thought I should share my concern with you.... Hope all goes well, however your build it.
1 The drive shaft needs to be 3” shorter
2 The T-5 shifter will need to be cut, bent slightly over, and welded back together. Angle is trial and error. Makes up for the “twist” of the T-5 with respect to your Muncie bellhousing. Bolt pattern is the same
3 The yoke is same spline as small, fine spline Muncie, 350 TH. But if you have the 32(?) spline, 400 TH yoke you’ll need to change
Been “Treed” on part of this
Good info here.... https://lugnutz65chevystepside.weebl...info-page.html
Steve O.
I guess I can already start disassembling the console. That shifter is going to have to come out as well. I’ll need to support the engine so it doesn’t tip
over.
Hm. Once the Muncie is out I can check for evidence that could be leading to my vibration issues. My guess is the tail housing is out of round. The bearing was so trashed it actually was cracked through.
,Shifter
I probably will cut the exhaust holes from the top so I can drop the trans whole leaving exhaust in place. Another reason, in Belgium if the MOT sees this cut they might have issue. It’s best for it to be on the top side. It needs to looks as stock as possible.
