From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Originally Posted by zwede
The oil pressure is normal for a fresh engine, no worries there.
Intake gaskets are indeed the next thing to check. Have you had someone follow you and check when it smokes the worst? If it smokes the most under heavy load it points to rings. If it's the most under decel it's something in the heads/intake like intake gaskets, valve guides/seals etc.
I see you have not read the whole thread dont blame you. I have had 4 or 5 guys follow me and all agree it smokes bad out the right side after letting off from a pull, in other words high vacuum. I can see this in the rearview mirror. Left side has minimal smoke but you can make some out !
Oil pressure is normal. I would check some valve guide seals first since that is easier than the intake.
You'll need a valve spring removal tool. I use rope in the cylinder through the spark plug hole with a bit sticking out then jam the piston against it. The rope will give the valve something to push against while you compress the springs and again keep the valves up when you put the springs back on.
This is the one I have now. It's a whole lot better than other ones you'll find that are cheaper, but a whole lot harder to use. I also use a magnetic pick up tool to remove the keepers so I don't drop them down a hole in the heads.
Guilty as charged.
That's kinda good news as it looks more like intake gasket than rings. Easy enough to fix.
Originally Posted by drwet
Gotta hear the answer now.
I talked to one guy in Stafford and he said to call in August and we will set something up for the fall. Another said he is not taking on new work at this time. These guys were highly recommended.
August??! This is why most of us that drive 40+ year old cars do our own wrenching. For the cost of an intake gasket and a six pack, and about four hours out of a weekend, you can determine if its the intake gasket leaking. (By the way that's where I'm putting my money, if anyone's starting a pool.)
I also have 2 other cars, 4 bikes, an Aussie, horses, and let's not forget the wife and kids. 4 hrs??? Maybe a year from the next blue moon! They have already taken a peek at the valve seals and just confirmed they are all there!
Stafford ... racing season is upon us (as well as around Stafford Speedway) ... shops must do quick turnaround for their regular bread-n-butter customers ... one & done customers start at the back.
I've thought intake gasket install (particularly the work / choice of gasket) from get go and posted same much earlier ... still do. Clever fellow with a few tools should be able to R&R an intake.
Ok... so the installing shop opened a warranty claim with ATK. Next day tech guy calls them and gives them the same song and dance they give me , run a line to the AC. Shop explains that the customer just put 100 miles on car with WITH THE PCV DISCONNECTED and AtTK says run a line to AC.then put at least 75 miles on the car Shop and I think they are just following a standard protocol. Shop wants me to take the car again to put the mileage on after they instal ATK specified part number PCV and ac line. This time I'm going to take the car and say see you in an hour, it's not coming home and losing more days!!!
Have you run the hell out of it to seat the rings?
No way in hell would I let that shop touch the car again. Warranty or no Warranty.........the headache isn't worth it.
Jebby
Ok.....So now on the advice of the engine builder we pulled the Rocker arm studs and found minimal thread sealer and evidence that oil had been sucked thru the threads as the builder expected. We cleaned everything up , applied liberal sealer and re-torqued everything, then re did the valve clearances. Now we need to put on some miles... again! I wonder what else is wrong with these heads, the whole valve train was re-checked!
Wow, that sounds like a long shot to me. Good luck with it, though.
