Vacuum Pump Recommendation?
Old May 31, 2020 | 07:50 AM
KJLive's Avatar
KJLive
Default Vacuum Pump Recommendation?
Hi. I am not very mechanically inclined and was hoping for some recommendations from forum members. A while back a friend installed 2.02 aluminum heads on my 350 CI (not original), motor. After the change, I needed to purchase a larger intake. Since the upgrade, the wipers and headlights will not work. I tried a variety of different suggestions to no avail. Since the car is fully customized and not original, someone suggested just purchasing an electric vacuum pump opposed to searching for answers to correct the original vacuum system. Any recommendation on what I should consider purchasing? Thanks in advance for your help.
Old May 31, 2020 | 09:18 AM
68blvert's Avatar
68blvert
Are you sure the main vac line was hooked back up? Since both systems are completely dead, sounds like no vac feed.
Old May 31, 2020 | 10:45 AM
Bikespace's Avatar
Bikespace
Did you get a new cam at the same time?
I'd look for the simple stuff first (vacuum leak in a hose, incorrect routing, or missing hose), then look for vacuum leaks elsewhere. A vacuum gauge will make this a lot easier. What is your idle vacuum now?
Have you done the @lars style tune, to include setting idle mixture to maximize idle vacuum?
Old May 31, 2020 | 04:59 PM
KJLive's Avatar
KJLive
Yes. Everything seems to be hooked up correctly. I checked and double checked I also bought a new filter.
Old May 31, 2020 | 05:01 PM
KJLive's Avatar
KJLive
I did not get a new cam. The vacuum seems to be building, but not enough. I have not tried a vacuum gauge and probably need to also consider this step.
Old May 31, 2020 | 05:41 PM
Bikespace's Avatar
Bikespace
A vacuum gauge will help you diagnose the problem, and help us help you. You may also want to pick up a pack of vacuum caps to help isolate the problem to a specific system. If you engine is making good vacuum already (or can be tuned to do so), you don't need a vacuum pump. Hopefully that is the case.
Old May 31, 2020 | 07:11 PM
7T1vette's Avatar
7T1vette
There is a line disconnected, somewhere. Normal vacuum sequence is from intake manifold to vacuum reservor, then split to the various vacuum-operated systems: headlamp buckets, wiper door, and HVAC system. Follow the vacuum source line to make sure routing is correct and no connection point is left open.
Old Jun 1, 2020 | 07:35 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Put a vacuum gauge on it.......set the timing per Lars sheet, post your results. Timing can cause low vacuum, so can an intake leak. Simply changing the heads and/or intake will not lower vacuum.
After setting timing.....set idle mixture screws for highest vacuum at idle.
If your system worked before.....it will work again.....
Jebby
Old Jun 4, 2020 | 05:10 AM
KJLive's Avatar
KJLive
Jebby
Thanks everyone! I will explore these options and see what happens. I appreciate the help!
To Vacuum Pump Recommendation?
