CorvetteForum Loaner Carb Program Update
Old Nov 29, 2002 | 09:17 PM
lars's Avatar
lars
Default CorvetteForum Loaner Carb Program Update
I've had a few people ask me if the "Loaner Carb" Program is still up and running. The answer: Absolutely!
For those who are not familiar with it, we started a "Carb Loaner Program" due to the incredible amount of tuning problems that were being experienced by C3 owners (and some C2 guys). It's often tough to tell if our problems are due to carb issues or ignition issues... sometimes there are other problems. To help our Forum members with this, we had a bunch of Forum people send their spare Q-Jet carbs to me, and I've been refurbishing them and loaning them out ever since.
These "Loaner" carbs are available to all Forum members and Corvette Enthusiasts for troubleshooting and assistance at no cost. You just have to send me a check to re-imburse me the postage costs on the package when you recieve it, and you have to send the carb back to me in a reasonable amount of time so others can use it, too. Other that that, you're assured of the use of a well-tuned, good-running Q-Jet to help you trouble-shoot and diagnose your car.
Some comments and updates on this program are contained in a topic folder at this location:
http://forums.corvetteforum.com/zerothread?id=441966
Maybe some of the guys who have borrowed the Loaner Carbs can drop a few comments about their experiences here.
Contact me with any questions about this somewhat unique Program.
[Modified by lars, 8:21 PM 11/29/2002]
[Modified by lars, 8:24 PM 11/29/2002]
Old Nov 30, 2002 | 11:47 AM
7Bob3's Avatar
7Bob3
Default Re: CorvetteForum Loaner Carb Program Update (lars)
TTT
Old Nov 30, 2002 | 10:44 PM
ice pac's Avatar
ice pac
The Carb Loaner Program is a great help to the forum. My '81 was missing many of the components for the electric controlled carb and it wasn't working right. Lars told me about the program and sent me a refurbished non-electric carb from a '79. I havn't installed it yet(work, school, and no time). I planned on getting to it this wednesday and I'll update when I see how it runs. Thanks again to Lars and all the members who make this program possible. :cheers: :flag
Old Dec 1, 2002 | 12:10 AM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
lars,
A question...
In the process of getting my vette on the streets I had my Q-Jet rebuilt just so I knew it was not the problem I was having. Ends up it was totally something different. Getting to the point... I have decided to pull the matching #'s engine in favor of putting more power under the hood and when I do I will not need that carb for the foreseeable future. I do not want to give it up permanently as I will be rebuilding that engine and want to keep it intact, but I'd like to offer the carb to those in the Houston area who might be having problems. I'm sure you all would like to keep control of the quality aspect of knowing that the carbs you rebuilt will in fact work, but I would be willing to offer a localized effort to those who do not want to wait and just want to see if that is their problem. If that is out of line, let me know.
If not... I'll contact you when I have the engine in the dismantling phase and you can send forum members in the Houston area my way.
Old Dec 5, 2002 | 12:22 AM
ice pac's Avatar
ice pac
I finally installed the carb today. I had all the other engine work done and it was time to finish up and get it running again. The carb went in pretty easy no problems with the exception of swapping the fuel line. The metal line had been kinked badly near where it connects to the carb and I found out why. The bolt had been badly cross-threaded. When I tried to get it off the kink ended up busting. So now I need a new fuel line. Hopefully I'll be able to change that out tomorrow. I can't wait to see how it runs though. It already looks 100% better than when I got it. :chevy
Old Dec 5, 2002 | 12:32 AM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: CorvetteForum Loaner Carb Program Update (ice pac)
I'll chime in.
This program is really awesome and one of a kind. I used one of the Holleys that Lars had and it started up on the first turn of the key. Ran like a champ. I even used the carb in my first autocross and got 3rd place. If any of you are in need of either trying out a different carb or need to troubleshoot some other engine issues then try out the carb loaner program. So when are you going to start the big block loaner program, Lars? :yesnod:
Old Dec 5, 2002 | 02:27 AM
The Dude's Avatar
The Dude
Lars, I haven't returned No 12 to the program yet. He's still sitting in the garage and as soon as I can stuff him in a box he'll be back on his way to you.
Old Dec 5, 2002 | 11:47 AM
1yy07's Avatar
1yy07
THANKS AGAIN MR LARS, carb and dist help,once again TIME and MONEY WELL SPENT! :smash: :cool:
Old Dec 5, 2002 | 11:58 AM
TedH's Avatar
TedH
Lars, I still have a major stumble between my 1-2 shift of my 700R4 as it drops rpm's by nearly 800. I've been told there is a 'TVS' linkage fix but I've also tried varying the setting of the adjustable TVS that came with the trans to no avail.
Prior to installing the main jets and metering rods that you sent me, I had also retarded the timing a few degrees as I was experiencing such a fast idle that the idle speed screw was backed to its limits and I still had idle over 1000rpm in Drive. At this time, I have 800rpm idle (after warmup) and the jets/rods you sent me... and the stumble at 1-2 shift. I will try advancing the distributor a little again back to what I had it at before and see if that helps.
I don't expect that I need to richen any more as that will likely cause a flooding situation.
If you know of a trick or two that I can try, I always welcome suggestions.
Thanks! :seeya
Old Dec 5, 2002 | 02:32 PM
NHvette's Avatar
NHvette
Default Re: CorvetteForum Loaner Carb Program Update (TedH)
I may have an old Holley lying around somewhere.
Would this be useful ? I think I ran the #s at Holley once - and it was a 1967
780cfm unit.
:seeya
To CorvetteForum Loaner Carb Program Update
