Engine tries to rev back up
Old Sep 4, 2020 | 04:25 PM
Punkchachi's Avatar
Punkchachi
Default Engine tries to rev back up
I have a 400 small block with a 750 demon carb. When I got it the guy said I would have to take it to have the carburetor tuned because he put it on and didn't mess with it. Sometimes, not always when I shut the car off about 1/4 later it will try to rev back to life for about 1/2 a second then shut off. Should I be really concerned about this or is it just the carb needing to be tuned?
Old Sep 4, 2020 | 06:00 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Your car is dieseling and needs to be tuned.
Old Sep 4, 2020 | 06:09 PM
MelWff's Avatar
MelWff
What is your idle speed?
Are you using the correct octane gasoline for your compression ratio?
Old Sep 4, 2020 | 06:25 PM
Punkchachi's Avatar
Punkchachi
Is "dieseling" going to damage the engine?
I use 93 Octane, it's what the guy told me to use.
I will have to get back to you on the idle speed, I honestly don't know what it is. I'm thinking it's around 800 but I'll let you know.
Old Sep 5, 2020 | 03:45 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Running on, or dieseling is Not a good thing. Most commonly caused by incorrect timing. Incorrect idle speed and or idle mixture can also contribute.
As stated above. Your engine needs tuning. NOW.
Old Sep 5, 2020 | 07:28 AM
Bikespace's Avatar
Bikespace
Yup. Timing. Email @lars on this Forum for his timing papers. Your timing is likely retarded. PM me if you can't find his email address.
To Engine tries to rev back up
