need help 72 big block
Old Oct 29, 2020 | 11:21 AM
joel price's Avatar
joel price
Default need help 72 big block
I need a belt configuration diagram or picture for a 72 454 with ac,ps,and air(smog pump). Assy manual doesn't .show. Also is an idler pulley necessary on this set up please help
Old Oct 29, 2020 | 11:46 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I found it in my 72 AIM on pg 181
Bottom center pic is BB AC and PS and has idler pulley
File Type: pdf
Old Oct 29, 2020 | 11:54 AM
lars's Avatar
lars
Here is the drawing in the AIM so you don't have to download the .pdf:
Lars
Old Oct 29, 2020 | 02:21 PM
joel price's Avatar
joel price
thanks but none of these have AIR,ps,and ac AIR is missing on each. I have an AIM
Old Oct 29, 2020 | 03:03 PM
lars's Avatar
lars
Sorry, missed the A.I.R. requirement. Here you go:
Old Oct 29, 2020 | 06:52 PM
joel price's Avatar
joel price
thank you
Old Oct 29, 2020 | 10:22 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Originally Posted by lars
Strange that that AIM illustration shows the main crank to water pump belt going around the idler pulley. All illustrations I've seen showing the A/C idler have it pressing against the belt from the outside rather than inside the belt loop.
Old Oct 29, 2020 | 11:32 PM
71 Green 454's Avatar
71 Green 454
The only difference between your '72 454 and my '71 454 belt configuration is the A.I.R.Pump that uses the AC Compressor belt.
Yes, the idler pulley (454's with AC) is necessary so you can tighten the belt if or when is stretches.
Without that belt, everything is relying on the power steering belt.
Old Oct 30, 2020 | 09:18 AM
toylman's Avatar
toylman
Here's my 1972 AIM corrected page with the GM part numbers, Quanta part number and belt length.
Old Oct 30, 2020 | 10:54 AM
PJO's Avatar
PJO
Veteran: Marine Corps
my 1973 AIM has a better illustration.
Old Oct 30, 2020 | 02:25 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Excellent info!
From what I could gather on the history of the 72s, the LS5 as planned originally for 72 had no air pump and the LS6 did. But then they didn't pass emission certifications, and California's were different anyway. My 72 AIM shows things at that step. Then at a very late date before production the LS6 was cancelled completely for 72, (presumably for failing emissions) and the LS5 grew an air pump. The LS6 deletion apparently just made the AIM but the LS5 air pump did not make the corrections. IIRC even the air pump equipped LS5 was banned in Cali that year. Not sure if that was because it didn't pass the second time or they just didn't go thru it again for only 1 state. Parts books are strange as well in this area.
GM was really struggling with this new-fangled emissions compliance back then!
To need help 72 big block
