Fixed the horn
Old Jan 31, 2021 | 06:26 PM
Sayfoo's Avatar
Sayfoo
Default Fixed the horn
Recently, the horn on my '69 wouldn't work once the engine warmed up and heated up the engine compartment.
So, I worked on looking for bad wire connections, bad relay, etc.
I'd spend a hour or so every once in a while, but couldn't find anything wrong.
Then, I was reading about rag joints and how the original ones had a grounding ribbon across them. I did replace mine 15 yrs ago. Not sure if it was a GM, NOS, or replacement. Either way, it worked for almost 15 yrs. I decided to run a ground wire jumper across the rag joint. I found a old braided cable with soldered on metal ends that was the perfect length.
Today, the hot horn worked.
So, just a FYI, if you're having intermittent horn problems, check out your rag joint. Why it worked for almost 15 yrs them quit, I have no idea.
Old Jan 31, 2021 | 06:56 PM
HeadsU.P.'s Avatar
HeadsU.P.
Good job. Now you have to remove your bumper sticker:
Horn Broke
Watch For Finger.
Old Jan 31, 2021 | 11:44 PM
7T1vette's Avatar
7T1vette
The fiber disc in the stock Chevy ragjoint was made with metal mesh in it. That metal would conduct to both sides of the joint and acted as electrical ground for the horn. Glad you found the cause of your problem.
Old Feb 1, 2021 | 11:15 AM
Sayfoo's Avatar
Sayfoo
Horn Broke
Watch For Finger.
Well, I'll remove 1/2 of it.
Old Feb 1, 2021 | 08:59 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Just got my steering box rebuilt by Gary (GTR1999) and am trying to figure out which of two rag joints that I have should eventually be used with it later when I reassemble everything.
My old rag was worn with a tear in the disc by one of the bolt holes and also the thin soild ground strap was broken, but the disc did not appear to have any mesh.
Replacement option 1 is my rebuilt rag with a new mesh-less disc, but with a new ground strap added.
Option 2 is a used rag in very good condition I bought from E-bay that has the mesh, but does not have the ground strap. I do have a new ground strap for this also, but to install it, I'd have to drill out one of the riveted posts and replace that with one bolted-on post from another rebuild kit (I'd leave the other riveted post unmolested).
Which would you all recommend for me to try first?
Paul
Old Feb 1, 2021 | 09:23 PM
7T1vette's Avatar
7T1vette
I would choose an original GM joint...IF the disc was in good condition (pliable and not beginning to crumble)....because the quality of the metals and materials used is SOOOO much better than what is being sold in the aftermarket. Just add a braided copper grounding wire which is connected to metal on both sides and to steering and box shafts.
Old Feb 1, 2021 | 09:36 PM
Sayfoo's Avatar
Sayfoo
I'd go option 1, if you can get a good disc.
Option 2, I would not drill out anything.
I used a mesh strap from ???? that I bolted under both cinch bolts on the rag joint.
If you're real industrious or bored, you could drill and tap both sides of the joint and jumper it this way.
Old Feb 1, 2021 | 09:43 PM
GTR1999's Avatar
GTR1999
Hi Paul
The 63-71 rags were grounded by a beryllium copper strap between the pieces. They didn't last long, most times worn thin and broke. In 1972 they replaced the strap design with the mesh impregnated on one side of the material. It worked well and would stick you in the finger if you touched it on the side. The rags were made by Saginaw and also an aftermarket one by Tom Reina who owned Corvette Steering. Tom supplied high quality rags and supplied LICS among many others. GM sold them for $50 up til 10 years ago. Now one is easily $300 sometimes more and sometimes less. The current rags are not close to the quality of the GM/Saginaw or Tom Reina's. Any that are ripped are no good. If too dried out they will soon rip as well. If the column is collapsed the rag will form an "S" bend where it has to be flat once installed.
The best are still the NOS GM or Tom Reina's. Several vendors were going to save the world and get them made the past few years but all found out the material is gone and to get it made would be an expensive deal, so the imported ones are on the market today.
Old Feb 2, 2021 | 02:50 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Thanks guys.
I guess I'll use the good GM rag with the mesh and see how it works grounding wise without the ground strap. If needed, I can then rig up some sort of braided wire connection between the pieces to improve the ground. I'll keep the rebuilt one with the beryllium copper strap as a back-up if I should live long enough to ever need a replacement...
To Fixed the horn
