Bleeding brakes
https://www.performanceonline.com/GM...Tool-AC-Delco/
Follow the thread below for more info.
https://www.corvetteforum.com/forums/c3-general/4371698-bleeding-my-brakes.html#post1601008013
None of my business but, why are you not using the stock brake line configuration from the master to the D. Block? You have set yourself up for two additional leaks with those spliced lines / joints.
If the new lines going into the MC ports are not flared, they will never hold a seal. Inside the MC ports is a matching flare that is part of the iron castings. Only a flared line should mate up to those ports.
The two ready made brake lines from the MC to the D. block are not expensive, are pre-bent to the perfect angle and fit correctly.
Also, by you removing the so called distribution block as a potential problem, you will have to re-bleed again when you reinstall the block.
I don't believe you should ever use a thread sealer on brake line fitting. DOT3 is a solvent and would destroy the paste soon.
And last but not least: Is your MC / Booster rod adjustable on your model yr? If so, what is your gap between the two? A gap of 0.060 or about 1/16 inch is ideal.
So, just to clarify, this is for the bleeder valve threads only, never the brake line fitting. I've mangled enough of those without Loctite.
The idea with the Motive is to pour two bottles of DOT3 in the tank, pump it up and bleed all four screws on the rear at one time.
Then do the fronts. Never touch the pedal.
So, you are saying to have all 4 rear bleeders open at the same time? I can see that could help get air past the little block in the rear that divides the left from the right.
Yes. Not wide open, but all four bleeders "trickle" open into a clear hose, into a water bottle etc. Consider the procedure a semi-gravity bleeding assist process.
Closing the bleeders in the normal bleeding order RRO, RRI, LRO, LRI, when the bubbles cease. Then RF>LF done.
https://www.zip-corvette.com/67-68-m...roduction.html
https://www.ecklerscorvette.com/1967...-162821-1.html
https://www.topflightautomotive.com/...oaAtoSEALw_wcB
Are you getting really good flow out of your bleeders?
Have you replaced the hoses to the calipers?
I ask about flow because when I do pressure bleeding I get so much flow that it's the easiest way to replace all the fluid with new.
