Having Problems Installing Distributor
Old Mar 25, 2021 | 08:22 PM
How Are You's Avatar
How Are You
Hello?
Old Mar 25, 2021 | 10:32 PM
jeffwebley's Avatar
jeffwebley
OP. As mentioned earlier, try turning the oil pump drive to better line up with the distributor shaft. Most likely scenario, is as you stuff the distributor, it turns due to the helix cut and the slot doesn't line up when it gets down to the oil pump.
I've never bumped the motor over when installing a distributor, just dilly-dallied with it till it went in.
Good luck
Jeff
Old Mar 26, 2021 | 07:15 AM
HeadsU.P.'s Avatar
HeadsU.P.
After going back to post #1 it reminded me of an issue on this forum yrs ago.
A poster had just bought a new Intake. Seems the hole for the dizzy was a little on the tight side due to being an off-brand.
Can't remember the final result. Maybe a little grinding here & there.
Is this your issue, new Intake?
Old Mar 26, 2021 | 08:13 AM
Chuck72's Avatar
Chuck72
Good luck
Jeff
Also, OP could be pushing down too hard on distributor, resulting in the oil pump drive pin actually turning the top of the oil pump shaft as he bumps it, instead of engaging. Generally, they just fall in.
Old Mar 26, 2021 | 08:15 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I have never installed a distributor and bumped the engine to get it settled in. Ever.
I stab it mulitple times going around each tooth until it falls in......then I look to see where the rotor is pointing. Turn the pump driveshaft with a long screwstick the direction the rotor needs to go....if you are going clockwise, stop a little short to account for the helix.
I suggest you do this now.....to see if the damn thing falls in anywhere...
Jebby
Old Mar 26, 2021 | 08:27 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by Bad-Mo-Faux
I have never in my life ever heard of someone installing a distributor gear upside-down. If this is what we get from a "Tech Advisor" here, I'll go back to the Facebook C3 group.
Good luck...I deleted every one I followed on FB......it's like ******** politics, nobody wants the answer......they just want to be "right". It opened my eyes to how many ******** there are in this hobby.
Jebby
Old Mar 26, 2021 | 08:53 AM
gjohnson's Avatar
gjohnson
Bumping the engine seems iffy at best. Should drop right in
Old Mar 26, 2021 | 04:27 PM
How Are You
Not a new intake, but a new distributor, same model as the one that was removed.
Jebby
I tried stabbing it on each tooth and didn’t go in.
Good luck
Jeff
I will try the screwdriver method.
Thanks for the help guys.
Old Mar 26, 2021 | 04:36 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If you have no luck.....inspect the inside of the distributor gear....the part the receives the oil pump driveshaft.....in fact, get another driveshaft and test fit it into the gear.....does it go right in? If not....sometimes replacement gears have no “leader” or chamfer to receive this.....the shaft will sit slightly cockeyed in the hole and no way will it take the shaft ( he said take the shaft LOL).....
The way to solve this is to remove the gear and chamfer....
I have seen this quite a few times, especially on MSD stuff, so it is worth checking....
Post your findings....
Jebby
Old Mar 26, 2021 | 09:22 PM
wwiiavfan's Avatar
wwiiavfan
Jebby
I haven’t stabbed a dizzy since the 80’s, but you describe exactly what I remember. Get that thing to drop in wherever it will go. Then where the rotor is pointing is your #1 spark plug wire. Sometimes you get lucky and #1 location is right where you want it. If not estimate how far backwards you need to turn the pump shaft, pull the dizzy, turn the pump shaft and drop the dizzy back in. Don’t think I ever had to do it more than twice to get it where I wanted. It really doesn’t matter where your #1 ends up on the cap—if your plug wires are long enough to reach.
Old Mar 26, 2021 | 09:26 PM
How Are You
I replied...I tried stabbing it on each tooth and didn’t go in.
Old Mar 26, 2021 | 09:36 PM
wwiiavfan's Avatar
wwiiavfan
Then Jebby and the others are right, check whether an oil pump shaft actually fits into the dizzy gear. Also the dizzy hole in the intake.
Old Mar 26, 2021 | 10:33 PM
  #33
forman's Avatar
forman
Jebby got it right on with the MSD gears ,, ask me how I know ,, LOL
Old Mar 26, 2021 | 10:55 PM
  #34
vettz73's Avatar
vettz73
You say that it is a new distributor. If you still have the old distributor, have you tried to drop in the old one to see if you have the same problem?
Have you compared the gear on the old with the new distributor to see if it looks the same?
Old Mar 27, 2021 | 07:29 AM
  #35
pltmgr's Avatar
pltmgr
Strictly an amateur here. Had to "clock" my distributor due to a number of bubba issues. the vacuum advance and tack cable vs the firewall are issues when installing the distributor. I try to have the wiring as close to factory position as possible to make it easier for myself and the next guy with future work..Used the screw driver method.
As precisely mentioned, just because the distributor is new doesn't guarantee its going to fit.
Old Mar 27, 2021 | 08:45 AM
  #36
wilcar's Avatar
wilcar
edit: If the distributor gear was installed upside down it was done at the factory because I didn't install it myself.
Maybe I missed it, but what brand and model distributor are you trying to install?? Lots off offshore crap being sold out there these days!
Old Mar 27, 2021 | 08:51 AM
  #37
7T1vette's Avatar
7T1vette
The distributor drive gear is helical (curved tooth), so the gear will want to rotate the shaft as it engages with the cam gear. You need to account for that amount of rotation when you insert the distributor in the block, so the drive gear pin and oil pump shaft slot line up once the gears are in final position. Practice makes perfect.
I agree with a prior post that you should practice the installation process with the OLD distributor. You KNOW that will assemble well with your engine. Once you have confidence with installing the old distributor, try it again with the new one.
To Having Problems Installing Distributor
Old Mar 27, 2021 | 09:22 AM
  #38
drwet's Avatar
drwet
And if you can insert the old distributor, you could remove the distributor gear from the old unit and install it on the new one. If it still won't go then the only other possibility I can see is the taper on the end of the distributor shaft isn't right.
Old Mar 27, 2021 | 09:54 AM
  #39
Elcransonator's Avatar
Elcransonator
Jebby
Old Mar 27, 2021 | 11:32 AM
  #40
3X2's Avatar
3X2
Another suggestion: remove the gear and install the distributor without the gear and see if it fits correctly. Look down the distributor hole to see which direction the oil pump shaft faces, rotate the distributor shaft the same direction and see if it fits. If it does, there is an issue with the gear.
