Belts too tight?
First I changed some belts that felt too loose, and that fixed it for a while.
Then it started up again so while it was in the shop they looked at it and said the PS pump was hitting the frame so they put a shorter belt in it to move the pump away from the frame.
It came back, worse after a few days.
I checked the belts and the alt belt was a little loose, so I tightened it up. The idler pulley was also a little loose so I tightened that too.
It's still there and I'm out of ideas. Could something be too tight at this point? I don't know where else to look...
Anyone nearby want to come check it out? I'll buy lunch!
my ps pump is almost hitting frame but that is because i put longer one on so i can actually remove and service my power steering fluid.. did you check fluid?
its so fascinating to hear the different components..the water pump is like smooth sounding,
the stethoscope is really clear but watch out for moving parts! Will it pick up squeal? Maybe ..it should transger noise vibration
Using a pry bar or screwdriver to get the proper tension on the belt and then tightening the bolts incorrectly could cause your pulleys to not be in alignment with each other and the belts may not be straight in the pulley groove.
I guarantee that I'm not equipped with the knowledge to know if something isn't adjusted correctly or in alignment.
Spraying water on my engine I can probably handle...
Did not check fluid, would low fluid make squealing noise when engine is revved while sitting still?
1 major problem I've encountered recently is the use of metric or thinner belts.
Belts should ride on their sides. If a thinner belt rides on the bottom of the pulley, you are getting a lot less friction. If your belts are riding below the rim of your pulleys, this could be the case. I believe that they should generally run mostly flush with the outside edge of the pulley.
A little off set of pulleys will freak some people out, but that is 1 of the good points of a fan belt. While desirable, it doesn't have to be 100% in line to work well.
Clean your pulleys. You may need to use sand paper if they're real rusty. Acetone will remove any oil or gunk. Acetone can also be used on the belts to remove oil and gunk.
When everything is correct, belts only need to be snug, not as tight as you can possibly make it which puts a lot of strain on bearings in the water pump, power steering pump, etc.
Inspect the pulley wear surface for polishing. It needs a certain amount of roughness. If it is really shiney, shinny, shi-nee, however the H it's spelled, the belt will slip.
Sand paper or bead blasting the pulley will usually bring the surface back to a useable surface. I prefer bead blasting.
Inspect the pulley grooves. They may be worn from a "V" shape, into a "U" shape, and the belt will slip.
If it's worn into a "U", the only real option is to replace the pulley.
And, yes, the belt is supposed to ride either flush, or just a bit proud. As long as it isn't riding deep in the groove, you should be good. If it is too deep.... the belt will slip...
Good luck.
Jeff
PS. Also make sure you have all the belts installed. Sometimes, the total drive load on the belts gets to be too much, if all the belts aren't contributing. And you guessed it... Slip
This also makes the belt a pinch longer because it no longer rides as high in the pulley.
We are mad as hell and we are not going to take it anymore! Bring back the American measurement of inches.
I just got this education from a parts store guy...behind the counter...really, he actually knows what he is talking about. THere is actually a good handful of guys local to me that really now about the old small stuff
The easiest way to check this is with a straight edge laid across the face of a pulley so it avoids the pulley crown and touches the outer edge of the sheave in two places. While maintaining contact, rotate the straight edge and see where it contacts other pulleys. You may need to remove the fan belts and even the fan to do this, but it is worth it or you will never resolve the problem. Also, pay close attention to the thickness of the sheave edges. Your pulley may appear to be perfectly aligned using the straight edge, but if one has a 1/8” face and the other a 3/16” face they can be misaligned. In the ideal world if you have misalignment, the crank and WP pulleys are aligned and the misaligned pulley(s) are closer to the engine. It is much easier to shim them out into alignment than to figure out how to move them back successfully. Good luck!
Ideally, the outer surface of a properly sized belt will run at the same level as the outer diameter of the pulley[s] on which it is running. Plus or minus of that is OK, as long as the 'sides' of the belt are [nearly] fully engages with the sides of the pulley grooves and the inner surface is not in contact.
See lots of info here https://www.corvetteforum.com/forums...out-belts.html
